586,103 active members*
3,531 visitors online*
Results 1 to 11 of 11
    Nov 2007
    10
    Rigid tap help.
    Hello, newb here from Wi.
    I just got a 94 VMC-15 running in Format 1.
    I made this rigid tapping program on Unigraphics and used a Haas post.
    Could any one help me edit this program to work on the Fadal with format1?
    T8 is 8-32
    T9 is 6-32
    Any help will be greatly appricated!
    Mark
    G49 T08 M6
    M5
    G0 X-7.5125 Y1.7375 S75 M3
    G43 Z1.5 H08
    G84 X-7.5125 Y1.7375 Z-.4 R.025 F2.3
    G80
    G0 Z1.5
    X-5.0875
    G84 X-5.0875 Y1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X-2.525
    G84 X-2.525 Y1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X-.4375
    G84 X-.4375 Y1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X.4375
    G84 X.4375 Y1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X2.525
    G84 X2.525 Y1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X5.0875
    G84 X5.0875 Y1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X7.5125
    G84 X7.5125 Y1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    Y-1.7375
    G84 X7.5125 Y-1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X5.0875
    G84 X5.0875 Y-1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X2.525
    G84 X2.525 Y-1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X.4375
    G84 X.4375 Y-1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X-.4375
    G84 X-.4375 Y-1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X-2.525
    G84 X-2.525 Y-1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X-5.0875
    G84 X-5.0875 Y-1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    X-7.5125
    G84 X-7.5125 Y-1.7375 Z-.4 R.025
    G80
    G0 Z1.5
    G49 T09 M6
    M5
    G0 X-5.0875 Y1.4075 M3
    G43 Z2. H09
    G84 X-5.0875 Y1.4075 Z-.35 R.025
    G80
    G0 Z2.
    Y.4675
    G84 X-5.0875 Y.4675 Z-.35 R.025
    G80
    G0 Z2.
    Y-.4675
    G84 X-5.0875 Y-.4675 Z-.35 R.025
    G80
    G0 Z2.
    Y-1.4075
    G84 X-5.0875 Y-1.4075 Z-.35 R.025
    G80
    G0 Z2.
    X5.0875 Y1.4075
    G84 X5.0875 Y1.4075 Z-.35 R.025
    G80
    G0 Z2.
    Y.4675
    G84 X5.0875 Y.4675 Z-.35 R.025
    G80
    G0 Z2.
    Y-.4675
    G84 X5.0875 Y-.4675 Z-.35 R.025
    G80
    G0 Z2.
    Y-1.4075
    G84 X5.0875 Y-1.4075 Z-.35 R.025
    G80
    G0 Z2.
    Nov 2007
    10
    I guess I could switch over to format 2 for my haas programs.
    Nov 2007
    10
    Ok,
    Im switching to format 2 and running this,
    Any one seeanny problems?????
    G49 T08 M6
    M5
    G0 X-7.5125 Y1.7375
    G84.2
    G43 Z1.5 H08
    G84.2
    G84.1 X-7.5125 Y1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X-5.0875
    G84.2
    G84.1 X-5.0875 Y1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X-2.525
    G84.2
    G84.1 X-2.525 Y1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X-.4375
    G84.2
    G84.1 X-.4375 Y1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X.4375
    G84.2
    G84.1 X.4375 Y1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X2.525
    G84.2
    G84.1 X2.525 Y1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X5.0875
    G84.2
    G84.1 X5.0875 Y1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X7.5125
    G84.2
    G84.1 X7.5125 Y1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    Y-1.7375
    G84.2
    G84.1 X7.5125 Y-1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X5.0875
    G84.2
    G84.1 X5.0875 Y-1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X2.525
    G84.2
    G84.1 X2.525 Y-1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X.4375
    G84.2
    G84.1 X.4375 Y-1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X-.4375
    G84.2
    G84.1 X-.4375 Y-1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X-2.525
    G84.2
    G84.1 X-2.525 Y-1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X-5.0875
    G84.2
    G84.1 X-5.0875 Y-1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    X-7.5125
    G84.2
    G84.1 X-7.5125 Y-1.7375 Z-.4 R.025 S75 M3 F2.3
    G80
    G0 Z1.5
    G49 T09 M6
    M5
    G0 X-5.0875 Y1.4075
    G84.2
    G43 Z2. H09
    G84.2
    G84.1 X-5.0875 Y1.4075 Z-.35 R.025 S75 M3 F2.3
    G80
    G0 Z2.
    Y.4675
    G84.2
    G84.1 X-5.0875 Y.4675 Z-.35 R.025 S75 M3 F2.3
    G80
    G0 Z2.
    Y-.4675
    G84.2
    G84.1 X-5.0875 Y-.4675 Z-.35 R.025 S75 M3 F2.3
    G80
    G0 Z2.
    Y-1.4075
    G84.2
    G84.1 X-5.0875 Y-1.4075 Z-.35 R.025 S75 M3 F2.3
    G80
    G0 Z2.
    X5.0875 Y1.4075
    G84.2
    G84.1 X5.0875 Y1.4075 Z-.35 R.025 S75 M3 F2.3
    G80
    G0 Z2.
    Y.4675
    G84.2
    G84.1 X5.0875 Y.4675 Z-.35 R.025 S75 M3 F2.3
    G80
    G0 Z2.
    Y-.4675
    G84.2
    G84.1 X5.0875 Y-.4675 Z-.35 R.025 S75 M3 F2.3
    G80
    G0 Z2.
    Y-1.4075
    G84.2
    G84.1 X5.0875 Y-1.4075 Z-.35 R.025 S75 M3 F2.3
    G80
    G0 Z2.
    156
    <snip>
    T8 is 8-32
    T9 is 6-32
    Mark
    G49 T08 M6
    M5
    G43 Z1.5 H08
    G80
    <snip>
    T08 M6
    M5
    G0 X-7.5125 Y1.7375 S75.2 G8
    Z1.5 H08
    G84.1 X-7.5125 Y1.7375 Z-.4 R.4 F75.2 Q0.03125
    G80 G9
    <snip>
    Format 1 might work with, but doesn't need G43 or G49, the H word is all that is needed. And
    H0 instead of a G49. Rigid tapping (if I remember correctly) uses some other G code before the G84.1 (rigid tap) is called. Also the machine must also support it to work. If you don't have a user manual you can down load it from http://www.fadalcnc.com/fadal_Tech_Docs1.htm .
    The shop where I work has 12 Fadals, but only 2 or 3 of the machines support rigid tapping. So it isn't used unless we are short on compression expansion tap holders.
    Safety - Quality - Production.
    Apr 2007
    64
    Here is how I do it in format 1
    TA,1
    M6T1
    S500.2M5G80
    X3.Y1.G8E1
    G84.2
    H1Z.1M7
    G84.1X3.Y1.Z-.375R.1Q.03125F500.2
    G80
    G0Z3.
    M5M9
    X0Y0E0
    G49Z0
    M1
    M6T1
    M2
    The spindle RPM and the feed must be the same.
    The "Q" will convert the RPM to the proper feed.
    It will tap into the part at a feedrate of F15.625
    Example: S500 X Q.03125 = F15.625
    Aug 2006
    36
    Here's my format 2:
    N3000
    ( TOOL INFO
    ( DESC: HSS TAP
    ( SIZE: 1/4-20
    G0G17G40G70G80G90
    M6T3
    H3D3Z3.0
    S0400.2M05
    /M08
    G84.2
    G00X.281Y-.375
    Z.5
    G84.1G98R0+.2Z-.375F20.0S0400.2
    Y-3.555
    G80
    M5M9
    G49Z0
    M01
    Seabrook Machine Company
    156
    The user manual format I example:
    N52 G0 G90 S.2 M5 G80 M90 Do not turn the spindle on!
    N53 G84.2
    N54 H1 M7 Z.4
    N55 G84.1 G99 R0+.4 Z-.3 F2000.2 Q.05 X0 Y0
    N56 X1.
    N57 G80
    The user manual format 2 example:
    N52 G0 G90 S2000.2 M5 G80 M90 Do not turn the spindle on!
    N53 G84.2
    N54 H1 M7 Z.4
    N55 G84.1 G99 R0+.4 Z-.3 S2000.2 F100. X0 Y0
    N56 X1.
    N57 G80
    Notice the R plan should be a minimum of .4 above. And notice the use M90, reference M93 high gain for rigid tape and M91 for normal milling.
    Jan 2008
    30
    Are you breaking taps? One thing I noticed is that your feed rate is rounded off. I would start by setting your post to output 4 decimal places for your tapping feedrate. I am not real familiar with format 1, but I would think that missing 0.0437 IPM could cause problems (pulled threads if the tap even survives).
    Jan 2008
    85
    G0G20G40G80G90
    T08 M6 (8-32 TAP)
    G0 G90 G54 X-7.5125 Y1.7375 S320 M3
    G43 H08 Z1.5
    G98 G84.1 Z-.4 R.2 F10.
    X-5.0875
    X-2.525
    X-.4375
    X.4375
    X2.525
    X5.0875
    X7.5125
    Y-1.7375
    X5.0875
    X2.525
    X.4375
    X-.4375
    X-2.525
    X-5.0875
    X-7.5125
    G0 G84.2
    G49 Z0
    T09 M6 (6-32 TAP)
    G90 G54 X-5.0875 Y1.4075 S320 M3
    G43 H09 Z2.
    G98 G84.1 R.1 Z-.35 F10.
    Y.4675
    X-5.0875 Y.4675
    Y-.4675
    X-5.0875 Y-.4675
    Y-1.4075
    X-5.0875 Y-1.4075
    X5.0875 Y1.4075
    Y.4675
    X5.0875 Y.4675
    Y-.4675
    X5.0875 Y-.4675
    Y-1.4075
    X5.0875 Y-1.4075
    G0 G84.2 M9
    G49 Z0
    M30
    *Canned cycles are active until canceled so you can continue to add locations with out calling up a new canned cycle. along with this you can change your R, Z, as needed.
    *Calculating Feeds and Speeds Cad/Cam brings up a good point, I use Feed x Number of threads per inch = RPM, one can calculate for metric if you like. Thus F10. x 32 threads per inch = 320 RPM this will ensure rounding off numbers do not affect the thread profile or tap breakage.
    *It has been awhile since I have ran a Fadal and this code may need to be slightly adjusted as to cancel of height offset.
    My Response to "It's Close Enough", "Is Your Tool Box and The Door Close Enough?"
    Aug 2006
    36
    Quote Originally Posted by dapoling View Post
    This OP was asking about rigid tapping. G84 is for use with an extension/retraction tapping head. He needs to use G84.1 and the formating that goes with it.
    Aug 2007
    95
    THE RIGHT WAY TO TAP
    I use this everyday- 6-32 TAP
    M6 T1
    G0 G90 S160.1 M5
    G84.2
    X0 Y0 E1
    Z.5 H1
    G84.1 G98 R0+.4 Z-.5 S160.1 F5.
    G80
    The S160.1 comes from the pitch 32 (make 320/2=160,then add the .1)
    I use this for all my taps, works fine.
  1. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  2. Rigid tapping
    By Ken_Shea in forum MetalWork Discussion
    Last Post: 12-20-2008, 06:35 PM
  3. Rigid tap
    By 100 in forum Haas Mills
    Last Post: 05-11-2007, 05:53 PM
  4. Tl-1, Rigid Tap
    By DEAN in forum Haas Mills
    Last Post: 02-10-2006, 11:12 PM
  5. Which is more rigid ?
    By Kammo1 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-23-2005, 08:00 PM
