587,072 active members*
2,907 visitors online*
Results 1 to 3 of 3
    Aug 2004
    218
    Y axis thread milling
    would it be possible to thread mill a hole in the side of a diameter with a Y axis CNC lathe.
    Feb 2006
    992
    I don't see why it cant, the draw back is how big the thread hole is. since the Y on CNC lathe lay on a web and if hole too big then machine will alarm overtravel.
    The best way to learn is trial error.
    Sep 2006
    57
    Mroy
    Don't know if I understand the application, but I think you are asking about milling a thread on the radial side of a part, not an end face.
    We do this radial type of hole, and it is a helical command that uses X,Y,and Z commands to generate the thread
  1. Thread Milling on a 5 axis lathe
    By Jr. Programmer in forum G-Code Programing
    Last Post: 07-28-2007, 01:09 PM
  2. Thread milling
    By wjfiles in forum MetalWork Discussion
    Last Post: 01-08-2007, 11:13 PM
  3. Thread Milling 3/8-18 NPT
    By shawn in forum G-Code Programing
    Last Post: 08-26-2006, 02:24 PM
  4. Thread milling, can anyone help
    By jtrav in forum Uncategorised CAM Discussion
    Last Post: 03-06-2006, 09:25 PM
