586,339 active members*
3,861 visitors online*
Results 1 to 5 of 5
    Sep 2006
    21
    X2 X-Axis Lead Screw Key
    I'm trying to remove the key from the x-axis lead screw. The hand wheel came right off but I can't seem to get the key out. First I tried prying up gently with a small screw driver. The I took an awl and stuck it in the end of the slot and tried prying up. Then I put a screw driver against the end and tapped gently with a hammer. Then I took a drift punch and tapped a little harder. ALL I succeeded in doing was mashing the key stock a little bit. How the heck do you get that darn key out?
    Try clamping a pair of vise grips on it really tightly then rock the vise grips around to try to break the key loose. If that doesent work put them on as tight as you can get them at a slight angle and tap the end of them with a hammer trying to drive the key up and out of the slot. Sometimes they can be a pain there pretty tight tolorances.
    lvittori,
    I use a pair of side cutters (dikes) and get the end of the key in the back of the jaws while resting the cutters against the shaft. While squeezing the cutters, pry against the shaft, it should come out fairly easy.
    Bill
    Bill
    Sep 2006
    21
    Thank you
    Thanks to both of you for the suggestions. I tried the vise grips first and it came right you.
    Lucian
    no problem anytime
  1. What Lead Screw
    By DMARCO in forum DIY CNC Router Table Machines
    Last Post: 02-08-2007, 12:49 PM
  2. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  3. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  4. Ball Screw or Lead Screw? Which is Better?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 07-28-2004, 02:49 PM
  5. Ball Screw and Lead Screw
    Last Post: 11-21-2003, 03:06 PM
