AFAIK, the Bandit was limited to hardware handshake. You might try contacting Albrights's CNC support services in Bozeman, MT to acquire a cable and a prewired RS232connector. I do not have the pinout data on the Bandit, but the ones I saw had a round plug of some sort. I do not know if the DB25 was maybe for tape deck or what went on.
I'd make initial attempts at communication using an old PC with a real serial port on it. There's enough frustration to be had getting the communications going without throwing USB in the mix.
