I am justing beginning to learn G code for a Haas mill.
I'm using a .4375" HSS reamer, speed 700 rpms at a feed rate of 5"/min., material is 12L14.
Code is
N10 G01 Z-0.7 F5.
N20 G00 Z.1
In manual reaming the method it's slow in and slow out (as I recall).
It seems to me that the G00 Z.1 will bring the reamer out at rapid rate.
So the question is ... should the code really be:
N20 G01 Z.1
I don't have the machine right now so I can't run a quick test.
Also are the RPMs and Feed rate about right?
Thanks in advance.
Pat H
