586,119 active members*
3,599 visitors online*
Results 1 to 7 of 7
    Question Reaming with G01
    I am justing beginning to learn G code for a Haas mill.
    I'm using a .4375" HSS reamer, speed 700 rpms at a feed rate of 5"/min., material is 12L14.
    Code is
    N10 G01 Z-0.7 F5.
    N20 G00 Z.1
    In manual reaming the method it's slow in and slow out (as I recall).
    It seems to me that the G00 Z.1 will bring the reamer out at rapid rate.
    So the question is ... should the code really be:
    N20 G01 Z.1
    I don't have the machine right now so I can't run a quick test.
    Also are the RPMs and Feed rate about right?
    Thanks in advance.
    Pat H
    Feb 2007
    464
    Do it like this.
    N10 G01 Z-0.7 F5.
    N20 Z.1
    Stefan Vendin
    Nov 2005
    219
    If you have a decent tolerance you can rapid out of the hole, assuming everything is rigid and you have no part flex. We do it all the time.
    May 2006
    265
    yes, rapid on the way out, if the tool will leave a mark, it would leave the mark with g1 too, so then fix that problem instead.. TIR and so on..
    Jul 2003
    263
    why don't you use a G85 or G86 command instead
    G98 G85 Z-.7 F5.
    G80
    If you can ENVISION it I can make it
    Thanks for the help....
    I tried it several ways and in my application it doesn't seem to matter.
    The holes look good ... no marks.
    Pat H
    Nov 2006
    59
    I'm with CNC-King use a can cycle. If your new to programming read a little about them in your manual, they will save you a bunch of time.
  1. Reaming
    By Bill in forum Uncategorised MetalWorking Machines
    Last Post: 07-01-2007, 06:22 PM
  2. Reaming Ti ?
    By Sprew in forum MetalWork Discussion
    Last Post: 06-29-2007, 08:41 PM
  3. Lasers, HAZ and hardening.... post laser reaming?
    By InspirationTool in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2005, 07:53 PM
