586,042 active members*
3,743 visitors online*
    May 2007
    4
    Incremental axis advancement
    Hi Guys,
    I have a problem with my Taig mill with Mach 3 and Dolphin Cad/Cam. When I execute a code on the mill it will sometimes run x,y and z at a constant speed but I can load the same program later in the day and it will run the axis in incremental or stop start. Why is this? Am I doing something wrong in the drawing or what. Need help.
    You may have a program running in background like updating the hard drive file index.
    Check the Task Manager when the machine is not running correctly, for programs taking CPU time.
    Mach3 requires a pristine system configuration.
    With the USB CamPod and SuperCamXp the machine movement will not be affected by Windows background system calls.
    Dennis
    http://www.super-tech.com
    May 2007
    4
    Thank you very much for the info. I will take a look at the task manager.
    Dell
  1. Switch to Incremental
    By moldmker in forum BobCad-Cam
    Last Post: 10-06-2007, 03:43 PM
  2. Absolute or Incremental
    By mikede in forum Haas Mills
    Last Post: 02-04-2007, 12:02 AM
  3. benefits of incremental?
    By paelscrit in forum G-Code Programing
    Last Post: 01-28-2006, 04:27 AM
  4. Incremental encoder
    By mihan in forum CNC Machine Related Electronics
    Last Post: 09-10-2005, 10:21 PM
  5. Absolute and Incremental
    By ACME in forum G-Code Programing
    Last Post: 09-04-2004, 11:45 PM
