Yesterday marked the 3 week point of my new RW15 mill from milltronics being under power , 240 hours and I am very pleased overall.
My only complaints at this point are probably fairly minor, there is a pretty constant flow of coolant running across the floor when the machine is in use, about 3 gals lost every 8 hour shift , makes for a very slippery and unsafe work space around the machine. I cant find the leak, it doesnt appear to be plumbing related.
The only other issue is a part fell out of the head onto the table yesterday that looks like one half of a 5/8" ball bearing , will post a pic later today.
Update as of dec 11th
No one at milltronics can identify the mystery part in the pic below, Time will tell if its a critical part .
Although I am very happy with the size , accuracy and performance of the RW15 , the table is very soft and is unhardened. Its much softer than any cast iron I have encountered . Based on this I dont believe I would purchase this machine again . I am planning to add another similarly sized machine in January and was hoping/planning to purchase an identical unit but this extremly soft table is just not acceptable for a work surface on a machine tool in my opinion . 4 other members here have contacted me with the exact same complaint
