586,035 active members*
3,805 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > ERROR MESSAGE; File disk offset....
    Jan 2007
    19
    I have a Haas VM3 Mold maker.
    The control randomly throws an alarm with the following error,
    "File disk offset"
    The only way I can clear this error is to power down the machine and restart.
    Has anybody experienced this before? If so were you able to find a real solution?
    Thanks.
    Oct 2007
    5
    What software version is on your machine?
    I've had that problem when using Ethernet and went away when the mill software was upgraded from M13.09F to M13.16F
    Jan 2007
    19
    I was thinking that an upgrade may solve this problem.
    I have an older version.
    I will give this a try, thanks.
  1. File Upload from Disk
    By Big"E" in forum Haas Mills
    Last Post: 06-16-2007, 02:35 PM
  2. Boot disk for EZ-Track DX, batch file?
    By mmm2003 in forum Bridgeport / Hardinge Mills
    Last Post: 01-31-2007, 06:47 PM
  3. G83 error message
    By HBFixedGear in forum Fadal
    Last Post: 01-30-2007, 04:42 PM
  4. Mach III error message-Help
    By bherr in forum Shopmaster/Shoptask
    Last Post: 05-19-2006, 01:11 PM
  5. gibbscam error message
    By donder in forum GibbsCAM
    Last Post: 05-31-2005, 06:16 AM
