My lathe after turning up shows "F" on master PCB, then after warming up shows "L" and, at last, after warming up again begins operate properly. May be anyone faced with this kind of problem?
Normaly in Fanuc 10T system While switch ON, it will do initial Hardware checK up during that time the display shows so many letters and shows 1 in Final for normal operation.
If you are having any problem Display shows the Letter corresponding the problem like F or L then machines stops at that point and will not proceed further
