Originally Posted by
amen23
I also dont have a clue how to configure my motor ect ....
I got a 1600 driver --- 200 step motors
15 tooth timing pulley attached to the motor connected to a 45 tooth timing pulley (3 :1 reduction i guess). the 45 tooth is attached to a shaft which has a 32 tooth timing pulley on a belt with a 5mm pitch ..... i read the mach2 setup and it still aint making sence ..please help!
by 1600 driver do you mean you have a driver running in 1/16 microstepping mode?
unfortunately your 32 tooth pulley driving your belt is just about going to cancel out your 3:1 reduction. If I am reading your post correctly 1 turn of your reduction shaft is going to move your axis 160MM. Is this corrcet?
Once I am clear I can help you calculate your steps per. for Mach.
If it works.....Don't fix it!
