586,035 active members*
3,908 visitors online*
Results 1 to 7 of 7
    Nov 2005
    219
    How to decifer Ladder Logic???
    I know what some of the symbols are, normally open and closed switchs, coil symbol and so on, but the addresses have me a little confused.
    I believe the "K" addresses are for Keep relays.
    Are the "D" diagnostic bit address's??
    Are the "Y"s physical outputs?
    What are the "R" addresses?
    what are the "F" addresses?
    I just want to learn so I can trouble shoot problems better and so on.
    thanks for you help
    Jon
    24221
    K=keep relays
    C=Counter
    D= Data Table
    F=CNC to PMC (BMI Bus)
    G=PMC to CNC (BMI Bus)
    R=Internal Bit Register
    X=Physical Inputs
    Y=Physical Outputs.
    The CNC and PMC communicate over the Basic machine Interface (BMI).
    These use pre-assigned values to communicate. For example the CNC sends M,S,T commands to the PMC this way.
    Al.
    Albert E.
    Nov 2005
    219
    Thanks Al,
    Where could I get more information about PLC Ladder logic??
    Is there a certain book you would recommend??
    24221
    The problem is every system uses some unique instructions, although there are many basic ones, In my case, I learned on one particular manufacturers product, once you have one type under your belt, it is an easy step to others.
    Any book you get is going to offer generic style programs, but I believe there are quite a few out there.
    If you intend working with a particular system, I would get the manuf. programming manuals and work with them, but of course you also need a system to practice on.
    If you are just getting into PLC's and do not presently have something to work with, I Believe Automation Direct offer some cheap PLC's and the S/W.
    Al.
    Albert E.
    Jan 2007
    91
    theemudracer check your pm box.
    -Jim
    Nov 2003
    98
    Here is a well written book to get you started.
    http://www.eod.gvsu.edu/~jackh/books/plcs/
    Bob
    Jun 2006
    31
    PMC programming manual
    Al.
    Hi Al
    Can you tell me where/how i can get the FANUC PMC Model K/L/M programming manual(ladder language) B-55193E.I have trouble with ladder of OMC/ATC
    thank in advance
  1. Ladder editing
    By luca_r in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-05-2009, 09:02 AM
  2. Fanuc ladder
    By guhl in forum Fanuc
    Last Post: 12-07-2007, 07:54 PM
  3. OTA/OTC ladder acess
    By Htech in forum CNC Machining Centers
    Last Post: 10-30-2007, 02:54 PM
  4. ladder descriptions
    By ktb100 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-28-2006, 02:04 AM
  5. Ladder logic
    By Chris Roth in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-26-2005, 05:29 PM
