586,075 active members*
4,085 visitors online*
Thread: geometry
    Apr 2007
    29
    geometry
    Hi!
    Can anyone help me with a Fanuc T6, this T6 does not have a geometry page, so the operator is using G50 for offset and tool comp. I was asked the question? How do you teach the tool with this specific control? I work on CNC’s, I do not run them, and so I do not know! I just thought I could get an answer here to help them out.
    Thank you.
    2932
    From what I remember (it was 24 years ago or so), you don't "teach" the 6-T. It's an old dog, and it doesn't learn new tricks!
    1. Zero out the machine.
    2. Set the position displays to 0,0
    3. Index the turret to the tool you want to set.
    4. Touch off the tool to the face of the part.
    5. Write down the Z Machine Position, i.e.: -10.756
    6. Add the amount of to remove from the face, i.e.: 0.03 + 10.756 = 10.786
    7. Touch off the tool to the OD of the stock.
    8. Write down the X Machine Position, i.e.: -12.594
    9. Add the diameter of the stock, i.e.: 2.99 + 12.594 = 15.484
    In the program:
    O1234 (FACE AND TURN 2.937 X 3.00 LG)
    G00 G40 (SAFETY FIRST)
    G28 U0 W0 (GO HOME)
    T0100 (SELECT TOOL)
    G50 X15.484 Z10.786 S2000 M08
    G97 S400 M03 (PRE-SET RPM)
    G00 X3.1 Z0.1 T0101 (RAPID TO CLEARANCE)
    G96 S450 (ACTIVATE CSS)
    G92 X-0.06 Z0 F0.012 (FACE END)
    G90 X2.937 Z-3.00 (TURN 2.937)
    G00 G28 U0 W0 (GO HOME)
    M01 (OP STOP)
    (REPEAT ABOVE FOR REMAINING TOOLS)
  1. Geometry from solids
    By GigaHz in forum Surfcam
    Last Post: 04-17-2007, 10:58 PM
  2. Dimensions on 2D geometry
    By mayhugh1 in forum SprutCAM
    Last Post: 10-26-2006, 05:02 AM
  3. Geometry from NC
    By rherman in forum BobCad-Cam
    Last Post: 09-21-2006, 01:10 PM
  4. Associated toolpaths and geometry
    By Paul G. Swartz in forum Surfcam
    Last Post: 09-12-2006, 05:42 PM
  5. Can v9 save geometry as a .dxf or .dwg?
    By badRandle in forum Mastercam
    Last Post: 06-03-2003, 07:33 PM
