586,070 active members*
3,598 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Change from metric to imperial
    Jul 2004
    59
    Hi!
    I have to machine a part that is dimensioned in mm. I was wondering whether is possible to create the geometry in mm and then translate everything in inches. Doing the conversion for each feature before drawing a line will be more than a pain in the neck, not to mention chances to make mistakes. All what I want is to be able to work like I do in SW, where I draw the part in mm and then by clicking a button I get everything transformed in imperial.
    Sep 2007
    217
    If you have X then you would need to do is change it from metric to English and you will be asked a question to convert the geometry say yes and it will make the model to English size.
    Apr 2003
    3578
    In "X" Alt-F8 then at the bottom of the window you will see it set for Metric do the drop down and set for English and it will Prompt you to scale for you. Then Click Yes.
    Cadcam
    Jul 2004
    59
    Thank you guys!
    I knew it should have been simple, but I didn't know how to do it...
  1. metric vs. imperial acme screws?
    By carsonau in forum DIY CNC Router Table Machines
    Last Post: 11-09-2007, 09:06 AM
  2. Metric or Imperial Ball Screws
    By chris1407 in forum Australia, New Zealand Club House
    Last Post: 08-07-2007, 11:59 PM
  3. Converting from metric to imperial
    By Pharkas in forum Mastercam
    Last Post: 05-04-2007, 04:46 PM
  4. Metric mm or Imperial inches? Please help.
    By alexccmeister in forum Benchtop Machines
    Last Post: 02-22-2007, 03:19 AM
  5. Metric Change Gear Combinations by J.W. Early Excel Spreadsheet
    By cncadmin in forum DNC Problems and Solutions
    Last Post: 05-26-2003, 09:17 PM
