586,110 active members*
3,186 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Need help engraving photos
Results 1 to 16 of 16
    Nov 2007
    34
    Does anyone out there know if there is a way to laser engrave photos in greyscale 8 bit mode? The programs that I am using are Photoshop, CorelDraw and Corel Photo Paint..I am getting fair results but its a bit of a pain trying to remove the extra dots that are not needed when I use the unsharp mask feature which I have to use in order to convert 1 bit bitmap mode. Greyscale mode would be great to engrave if at all possible?
    regards,
    Terry
    Jul 2006
    64
    Hi Terry,
    I've been engraving photos for quite a few years now and haven't had much luck engraving 8 bit images. Unfortunately you'll most likely need to look into one of the 3D renedering applications to pull this off successfully. I only know of one that works pretty well and that's EngraveLab. It's a bit pricely though; however, a sales rep will work with you if you're already using CorelDraw. I recall somewhere around the $500-$600 price range a while back. We primarily use PhotoGrav as well as our own in house developed photo engraving application.
    Best of luck to you and happy engraving!
    -Ed
    nosplinters.com
    Dec 2007
    23
    I have had an unbelievable luck with Photograv, you can purchase it from laserbits.com. I think its about $350 and works well with 8 bit grayscale. Here is a couple pictures I did on absolute black granite.
    Aug 2005
    191
    Damn, that's nice.
    Dec 2007
    23
    Thanks here are a few more, all on stone. If your engraving on stone remember that each stone as a different crystal structure, I found it easier to start off at a very low power and see the result and increase the power to get what you want. You can engrave on piece and then go to another and have completely different results. Also in Corel there is a Tone curve that is very useful to bring down the very bright areas of the picture so the laser will not bleach out the photo. You can do this also in Photograv under the gray scale balance. Here are few more pictures.
    Attached Thumbnails Attached Thumbnails DSCN2709.JPG   dscn2963.jpg   DSCN2967.jpg
    Nov 2007
    34
    Quote Originally Posted by largohome View Post
    Veryyyyyy nice indeed..Incredible what one program can do and not that I am complaining but its just too much $ for me at this time unless perhaps some out there are getting out of the business?
    regards,
    Terry
    Mar 2007
    12
    Largohome, nice results you're getting. I purchased a large capacity laser, 55w using CorelDraw and Photograv, and was never happy with the results.
    Dec 2007
    23
    Thank you for your comments. There are a number of factors to get the results we are getting, first is the quality of the stone you are engraving, the closer the crystalline structure the better the etching, also some of this work you see is done in more than one file. On big images 2 foot or better I may do the face and skin of a person in a separate file (lower power setting), this means running the laser more than once over the stone your putting the image on. If the crystalline structure of the granite is tight (very small) you will need less power. I run my 60 watt co2 at 700 IMP with only 1.5 watt on the power on an average piece of stone. Very little power is required at slow speed of a big laser table. Second is to use corel or photograv to the max, I mean you have to understand the Photograv gray scale and line enhancement like the back of your hand to get perfect results. We are in the stone business, so I have been lucky to have many different products to work with and have experimented with them as it would be very costly for someone to purchase this product and experiment with it. On a new piece of stone the first thing to do is start out at a lowest power setting then increase to get the results you want. Do you still have your laser? I would be happy to show you if your ever in the area.
    Mar 2007
    12
    And to your quick reply. I still have my laser and from the looks of the settings you are using, I need some serious review our operating parameters. You're absolutely right on the software, you just don't scan and print and it's very expensive to experiment without good support. In the beginning, most of the parameters we received were documented from the companies 25w system. I know we purchased one of the first units with the 55w option and have always wondered if it was capable of the quality of etchings we saw from the demo.
    Sounds like the settings you listed are for granite. Much slower and lower power than I've seen todate. Note that I've only used the high quality 12"x12" Black Marble and other random tiles of Marble, Granite and Slate purchased locally so again, limited test runs with less than acceptable results. Would appreciate any assistance and would a chance to view visit. Which area are you in?
    Dec 2007
    23
    We are located in Missouri, my phone number is 417-475-4075, but email is the best way to catch me. [email protected]
    Mar 2007
    12
    Well surprise, so am I. I'll email you.
    Thanks, Danr
    May 2005
    101
    HI
    I would like to engrave Crystal. I have Chinese 50 watt 60 x 40 cm machine. What are the best parameters to engrave a Glass or Crystal with little deep. I have done many Crystal with different speed, power and DPI, but I could not achieved the good result. If any one have Chinese laser machine so what are the best parameters for the Crystal.
    Thanks in advance.
    Jul 2008
    776
    If you need really deep engraving - use sandblasting or mechanical engraving. Laser change only glass/crystal surface from glossy to matt. If crystal is expensive - may be better do not engrave with Chinese laser
    And do not forget use wet papertowel/newspapers during engraving
    May 2005
    101
    Litografa
    Many thanks for your kind suggestion.
    Regards.
    Jan 2007
    229
    Did you ever try converting the greyscale photo & convert it to bitmap via halftones ?
    Photoshop's well-kept secret!
    Quote Originally Posted by terry32506 View Post
    regards,
    Terry
    Hi Terry, what kinds of greyscale engraving do you want? The engraving effect will related to the sample material and also the Photoshop settings. We have finished engraving a photo on a marble. see the attachment. Is this similar to what you want?
    Attached Thumbnails Attached Thumbnails York Laser marble laser engraving samples.jpg
    www.yorklaser.com
    [email protected]
  1. help with photos
    By Mike Boarman in forum Mach Software (ArtSoft software)
    Last Post: 12-21-2006, 09:06 PM
  2. I need tip on engraving photos
    By harolda in forum Community Club House
    Last Post: 03-31-2005, 04:47 PM
  3. Photos of my DIY Cheap CNC
    By mikeschn in forum DIY CNC Router Table Machines
    Last Post: 02-04-2005, 01:40 AM
