586,111 active members*
3,324 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > Bending stainless steel tubing
Results 1 to 6 of 6
    Dec 2007
    17
    Hello,
    Can someone tell me what is the best tool to use for hypodermic stainless steel tubing. This would be very narrow tubing, about 18 to 20 gauge or roughly 1/8" thick.
    I saw there was a thread from a month or so ago that discussed stainless steel wire bending. I'm just not sure if that jig would work with tubing too.
    http://www.cnczone.com/forums/showthread.php?t=46236
    Thanks.
    Mike
    Oct 2006
    669
    There was a pretty decent article in Street Rodder magazine about the guy who does all brakelines for the Ridler Award winners...
    anyway, he routinely bends SS tubing and makes it look easy...
    don't know if it would help, but sometimes you find good information in the most unlikely places...
    Jun 2007
    12
    A rotary draw bender with a mandrel would give the least deformation.
    You mention 1/8" wall. What is the diameter?
    A wire bender would most likely result in flattening and reduction of the bore.
    Dec 2007
    17
    The wall is much less than 1/8". This is very thin tubing, 14 gauge.
    OD = 2.11mm
    ID = 1.6mm
    Wall thickness 0.0100"
    Aug 2005
    191
    You might want to try sliding a lightly lubed copper solid wire that just fits into the I.D., and then bend and pull out the wire. The tubing bends like its solid due to the inner support. Worth a try.
    Jul 2007
    13
    depends on the radius of the bend ,a standard brake line bender will do a good job a radius any smaller would require filling with something like lead or solder but would allow a very tight bend if the stainless is very brittle then the best is to use silica dust and hot forge the piece at 1400 deg f sounds like a lot of work for a small pc and I've had success in bending hard s s with just heating and no internal support on a 2 d bend
  1. Bending stainless steel tube, what tool?
    By Sperstad in forum Bending, Forging, Extrusion...
    Last Post: 12-17-2010, 01:11 PM
  2. Bending 7/8" 316 Stainless Steel
    By grantrobarts in forum Bending, Forging, Extrusion...
    Last Post: 05-03-2010, 10:30 AM
  3. 1/8" diameter 303 stainless steel rog bending
    By ssbender in forum Bending, Forging, Extrusion...
    Last Post: 11-06-2007, 05:34 AM
  4. RFQ: Tubing bending
    By Msport in forum Employment Opportunity
    Last Post: 01-20-2007, 05:27 AM
  5. Beam deflection using stainless tubing
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-16-2005, 10:26 PM
