586,655 active members*
3,145 visitors online*
    Dec 2007
    7
    bridgeport boss 8
    Please help I posted at the yahoo group didn't get a reply I have searched this and other fourms. Couldnt find a complete answer to my ?. I just bought a boss 8 mill. What drive do i need 320 340? What can Iexpect for ipm with gecko, is the limiting factor the parallel port orthe drives? Do I want to go with grex 100? I am using mach3 on 2gig512ram computer. I know I will need to reduce my voltage for the geckodrives can i us a varica to limit primary voltage to the transformer? I think I need to add an encoder tomy factory servos.
    Thank you for your help
    Dec 2007
    5
    Bridgeport Boss 8 Retrofit Wiring
    AdamD,
    I just ran across your post looking to answer some factory servo drive wiring questions. I have a Bridgeport R2E3 BOSS 8 that I am upgrading with a Camsoft Professional package. I have a set of factory wiring schematics but am unable to identify the servo drive motion command signal wires and the servo drive enable wires. I do believe the signal comes from a processing board (FMDC, DLI, ect.) but ??? I imagine that if you used the existing servo motors you have identified these wires. Any advice would probably help.
    Dan
    Nov 2009
    12
    is their any way i can get a copy of those wiring scematics
  1. Gecko in Bridgeport BOSS
    By zcases in forum Gecko Drives
    Last Post: 11-22-2009, 05:47 AM
  2. bridgeport series 1 boss 6
    By MR Custom in forum Bridgeport / Hardinge Mills
    Last Post: 11-19-2007, 02:04 PM
  3. Bridgeport boss retrofit
    By cat37 in forum Bridgeport / Hardinge Mills
    Last Post: 08-22-2007, 02:46 AM
  4. Bridgeport Series I Boss 4
    By millwrightguy in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2007, 02:07 AM
  5. YA Bridgeport BOSS capability
    By zcases in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-18-2006, 04:48 PM
