586,377 active members*
2,553 visitors online*
    Feb 2007
    4
    Spindel speed PWM controller
    I looked and haven't found a spindle speed controller for Mach3 for a generic router. What is needed is a feedback to the computer that tells Mach3 the RPM and a circuit that powers the router from the PWM pulses generated by Mach3.
    The index sensor can be a Hall sensor mounted to detect the rotation.. An optical system may be a problem with dust. For high speed routers a divider/counter to lower the pulse count to Mach3 will be needed.
    I designed a PC board to drive the 120V universal wound motor in most routers. It can be populated to run 5, 10, 15 or 25 amp motors.
    Comments please.
    Chuck
    24223
    Most ordinary routers are Universal motors and can reach high rpm, you need a prox that has a high freq characteristic, I have used the Honeywell Automotive gear tooth sensor GT1 series, they can also be obtained at auto scrap yards, they are used for Ignition timing on an engine.
    Also you could supply the digital tach feedback to the spindle controller, for a while there were surplus Treadmill motor controllers that were intended for Universal motor control, They were based around the motorola TDA1085 IC and had digital tach feedback input and Triac control.
    The IC was designed by Motorola for Washing machine Universal motor control and worked quite well, I still have one on my band saw I converted.
    Al.
    Albert E.
    Mar 2008
    80
    Can you give more information on the speed ocntrol board you designed?
    Jul 2010
    Yes Please more info on your motor controller!
    Feb 2009
    1290
    There is a unit available from CNC4PC that will do what you are doing however it is not a closed loop system. It just takes the output from Mach3 and sets the speed accordingly. It works fine for the people that do not need an exact rpm control. I have yet to try it at low speed as that will be the kicker, low speed usually means less torque on universal motors, correct?
  1. This Motors + This Speed controller?
    By JMcDonald in forum Benchtop Machines
    Last Post: 10-01-2007, 04:46 AM
  2. Quicker 2 spindel
    By satneo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-18-2007, 01:05 AM
  3. New Speed Controller for Routers
    By arturod in forum News Announcements
    Last Post: 08-14-2007, 07:01 AM
  4. speed controller?
    By slp_prlzys in forum CNC Machine Related Electronics
    Last Post: 09-04-2004, 09:40 PM
  5. Speed Controller recommendations?
    By paulried in forum DIY CNC Router Table Machines
    Last Post: 05-13-2003, 11:39 AM
