586,105 active members*
3,297 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Coding > Code help with offset cope...?
Results 1 to 2 of 2
    May 2008
    Hey all, I'm new to the boards, so I'm not sure if this is the right section to post in...Anyways, I'm a bit new to writing CNC programs. I've recently done a program to cut a square in the side of a pipe, along with a program to cut a cope. Both were fairly straight forward.
    My next goal is to write programs for an offset cope in the side of a pipe. This would include a program to cut the oblong (oval) hole in the larger diameter pipe, along with a program to cut an offset cope in the end of the smaller pipe.
    The cope program I have now can probably be modified slightly, but I'm not sure of the math formulas needed...same goes for the oval hole in the larger pipe.
    If anyone could give me a hand It would be greatly appreciated!
    Thanks,
    Casey
    4826
    Beats me about formulas, but I'd use a solid modeller to create the intersection I needed in cad first, then machine it with cam.
    First you get good, then you get fast. Then grouchiness sets in.
  1. Radius Offset and Length Offset
    By jim_stoll in forum Dolphin CAD/CAM
    Last Post: 10-15-2010, 01:47 AM
  2. Replies: 2
    Last Post: 05-25-2009, 05:22 PM
  3. Resetting the default Work offset code.
    By RdHawg in forum Fanuc
    Last Post: 01-24-2008, 01:24 AM
  4. G-Code Question, polar offset and pocketing questions?
    By mike71800b in forum LinuxCNC (formerly EMC2)
    Last Post: 03-20-2007, 06:07 AM
  5. Repeat g-code with y offset
    By tpaulson in forum G-Code Programing
    Last Post: 11-29-2004, 08:36 PM
