586,540 active members*
3,001 visitors online*
Results 1 to 6 of 6
    Mar 2005
    271
    How do you backup your config.
    Just got done setting everything up on my mill in mach3,just wondering how I save those settings that I have set for the motors and steps per inch? Any advise will be appreciated.Thanks Mike
    Mar 2005
    271
    I should say how do I back up the settings? Thanks Mike
    Just save a copy of the file Mach3Mill.xml
    Aug 2006
    231
    xml file
    Can you elaborate on how to create that file and use it if you needed to reinstall Mach to recreate all your settings?
    I just have a bunch of jpegs of screen shots of the different setting windows so I can manually reset everything if ever needed.
    Thank you
    Copy it from your Mach3 folder and either burn it on a CD, or put it somewhere else. When you reinstall Mach3, just copy it back into the Mach3 folder. No need to create it, it's already there. It's the file that all your settings are stored in.
    Mar 2005
    271
    Thanks ger21!!!
  1. Save as ????what
    By jorgehrr in forum Mastercam
    Last Post: 10-29-2007, 12:42 PM
  2. Save As .JPG?
    By TZ250 in forum BobCad-Cam
    Last Post: 09-28-2007, 01:56 PM
  3. How Do I Save As .JPG, .TIF or .BMP?
    By TZ250 in forum Dolphin CAD/CAM
    Last Post: 06-02-2007, 03:17 PM
  4. HAAS save all
    By gar in forum Haas Mills
    Last Post: 09-08-2006, 01:21 AM
  5. Mach 3 config?? HELP
    By ty1295 in forum Servo Drives
    Last Post: 02-20-2006, 07:20 PM
