586,103 active members*
3,776 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Default kernal speed in Syil inch profile
    Jan 2007
    93
    What is the default kernal speed in the SyilAmerica X3 inch profile? I tripped a breaker and the PC shut down hard. Every since then Mach has been complaining that the kernel speed of 25khz is to slow for the motor tunings. I suspect that I need to set the kernal back to 35khz but I've customized my profile quite a bit over the past few weeks and didn't want to accidently over write it by reloading the original from CD. Can someone post the default kernal speed and a few of the motor tuning numbers so I can see if I need to re-do those as well.
    May 2005
    925
    Quote Originally Posted by thackman View Post
    I can't help you with the units, but the profile (metric) I received was 35Khz.
    Jun 2007
    3757
    Question Problem with PC.
    25 Khz I think is correct.
    I had the error message come up because XP was making the PC busy when Mach3 started.
    Make sure no rogue programs are running.
    When Mach3 starts it enables it's driver, and at this moment the PC must be healthy and not busy.
    Mine is connected to a network, and every so often it goes off into the weeds at the wrong time. Restart Mach3.
    Use Ctrl-Alt-Del to see what else is running.
  1. default units
    By canadamaxxer in forum Solidworks
    Last Post: 10-07-2010, 07:05 PM
  2. Default SL-20 parameters question?
    By PaintItBlue in forum G-Code Programing
    Last Post: 11-01-2007, 11:48 PM
  3. Default feed override and manual jog speed settings?
    By InspirationTool in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-22-2007, 11:04 PM
  4. Mastercam 9.1 default settings
    By Fatty in forum Mastercam
    Last Post: 06-29-2006, 05:04 AM
  5. turns per inch vs threads per inch
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 08-18-2004, 03:27 PM
