586,075 active members*
4,219 visitors online*
    Sep 2007
    19
    Cool FANUC Ladder Logic Backwards?
    True or not true? A bit new to FANUC ladder but not to AB and such. Why does an output highlight and turn on even though it's rung functions are not highlighted? Troubleshooting is crazy like this! Why does FANUC do this? I'm on an 18-T . . . can anyone throw me a bone?
    May 2003
    75
    The only time I've ever seen this on a Fanuc control is when the output is written to in two different rungs.
    Paul Sevin - Ovation Engineering, Inc.
    http://www.ovationengineering.com
    24221
    Also occasionally it will happen if the rung is made except for one bit, if this one bit is changing fast it does not update on the screen but completes the rung the majority of time.
    As paul says, check for duplicate use of output, not very good practice however.
    For e.g. I have seen an output written in an Auto section and a manual section, and only one section is enabled at a time but the output will still show on in both.
    Al.
    Albert E.
    Nov 2003
    98
    Also look for the little tick mark in the rung \ this will invert the output logic.
    Bob
    May 2003
    75
    Another possible cause may be a jump function prior to the logic. Any logic placed between the jump & jump end functions won't be executed to completion when the jump function (SUB 10?) is enabled.
  1. fanuc-o ladder
    By Bill Clark in forum DNC Problems and Solutions
    Last Post: 09-29-2011, 07:35 PM
  2. How to decifer Ladder Logic???
    By theemudracer in forum Fanuc
    Last Post: 06-01-2008, 02:28 PM
  3. Fanuc ladder
    By guhl in forum Fanuc
    Last Post: 12-07-2007, 07:54 PM
  4. Fanuc ladder editing card
    By bob1371 in forum Fanuc
    Last Post: 04-10-2006, 04:50 PM
  5. Ladder logic
    By Chris Roth in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-26-2005, 05:29 PM
