586,114 active members*
3,099 visitors online*
Results 1 to 7 of 7
    Nov 2007
    how much cost synrad laser tube
    can onyone help me with price for synrad co2 laser tube 200w rf with power supply.
    Aug 2003
    494
    Hi oljeg,
    A 100 watt Synrad laser costs $16,000USD so I would think a 200 watt one would be around $32K - $36K plus the 80 amp power supply which will add several hundreds of dollars to the cost.
    Rich.
    I am not completely useless.......I can always serve as a BAD example.
    Oct 2004
    158
    Unhappy Expensive tube !
    Just for the tube???
    Wow - 'hate to think how much the whole machine is then...
    Bob
    Sep 2010
    Hello,
    did anyone gave laser tube (Sinrad model 48-1) on refill at lokal gas service?
    What is the procedure - important informations to make proper refill?
    I know it should be used CO2 gas. With how many bars (unit of pressure) should be filled? What installation - slip road is used?
    Have an old GCC Laser Pro model L-12 (12 W) made in 1999.
    Think this information would help lots of people.
    Mery,
    If only it were that simple.
    The Synrad 48-1 tube contains a mixture of gasses 5% CO2, 15% Nitrogen, 80% Helium and maybe others and it is in the tube at below atmospheric pressure.
    Tweakie.
    CNC is only limited by our imagination.
    Dec 2008
    1258
    The local gas service can probably provide bottles of 'laser mix' gas for a flowing gas laser but re-filling a Synrad tube is a different matter.
    The exact mix is proprietary but the base is as Tweakie mentioned, I would check with a local Synrad supplier or perhaps Litografa has a suggestion.
    Zax.
    Nov 2010
    787
    You can not regas Synrad lasers without specific knowlege (exact mixture, gas pressure etc).
    Regards
  1. Synrad 50 watt laser
    By KTP in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-11-2011, 09:38 AM
  2. Synrad vs. Laser Tubes + PS Questions
    By m_constrained in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 12-01-2010, 05:52 PM
  3. bad laser tube
    By cncadmin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-04-2007, 04:23 AM
  4. Synrad CO2 Laser available on Ebay
    By nelsonzjax in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-07-2006, 09:50 PM
  5. Synrad 10W Laser Available on Ebay
    Last Post: 12-07-2006, 08:36 PM
