We need to input parameters in a Mitsubishi spindle drive model MDS-A-SPJA-75. We don not kow how to do it, if anyone could help me with this it will be just great.
Thank you.
GP.
Thank you.
GP.
You could try looking through this lot,alternatively if it`s not on a Mazak [email protected] normally respond quite quickly.http://www.meau.com/eprise/main/site...anualType=Mark.
Yes I agree. You need a software for your PC and special cable to hook to the drive. You can also try to call (847)478-2100.
I have the SPJA & SPA transfer software, from when I converted a Spindle drive on a Mits Mazak Lathe from DC to the AC SPJA some time ago.
IIRC the software is DOS and only works on COM1 serial.
They use the current Micro-mini Din connector on the drive end.
Al.
Albert E.
