I need some help please. My lathe with a Fanuc 10TF control won't reference in X. I get a +X overtravel(SOFT) error message when I try to reference it. It started this after I powered it down and then back up after the monitor went blank. I am having monitor problems also. I found some info on bypassing this and tried it but it did not work. It said to hold P and Cancel buttons down while powering up and you can bypass the soft overtravel then reference machine and it will be ok. Is there another way.
TIA
