587,067 active members*
3,774 visitors online*
Page 1 of 7 123
Results 1 to 20 of 123
    Feb 2004
    427
    Started to build my plasma table.
    I have started to build my plasma table. I have used 65x65x2.5mm galvanised s.h.s. The size of the table is 3.5meters x 2meters. It is huge! It will be able to cut a full sized sheet of material, which is 3mx1.5m.
    I will take some photo's and post them up. The basic frame has just about been completed. I have 6 castor wheels on it to move it around, four of which are in the corners and are locking wheels.
    Feb 2004
    2337
    I can hardy wait for the pictures.
    Being outside the square !!!
    Nov 2003
    299
    Yeh, lets see some pics!!!
    Feb 2004
    427
    here are some pics
    Here are some pics of the table.
    3500x2000x900mm.
    Feb 2004
    427
    pics won't upload
    how do i upload a pic?
    i just went to browse and select the pic and submit reply and thats all that happened.
    Nov 2003
    299
    is your pic file too big? Try it again.
    Feb 2004
    427
    here is a pic
    Mar 2004
    1661
    I like your welding helmet.
    -Sven
    Feb 2004
    2337
    I dont know how plasma cutters work. But I was wondering if there was going to be a problem with cutting through those cross beams. Would it be an idea to have strips of steel in turned sideways in the middle. If you had slots at each end you could replace the strips as needed.
    Maybe plasma cutting isnt like oxy cutting!
    Nov 2003
    299
    WOW! That's a Monster! Looks good.
    Jan 2004
    353
    Re: Started to build my plasma table.
    Originally posted by Apples
    It is huge!
    Understatement Apples !
    Well done so far I'll follow this one with interest.
    (said it before and I'll say it yet again I really admire you guys that scratch build a machine as my recent retrofit has been an enormous amount of work/thought to complete)
    Feb 2004
    427
    i am going to have 4 lengths of angle iron welded onto those cross braces and then every 2inches or so cut a slot into the angle and insert some flat steel. The flat steel i will use would have to be around 75mm or 3" wide. that means that i should have 75mm of clearance between the bottom of my sheet of steel that i am cutting and those cross braces. Hopefully this is enough clearance.
    Yeah that is a pretty awesome looking welding helmet, it is an automatic darkening one too.!
    Feb 2004
    427
    Here is a new photo of my plasma table.
    Since the last photo, I have grinded back all the welds and painted the frame with one coat of charcoal hammerite paint.
    She is slowly coming along.
    Still deciding whether to use linear bearings with shafts and pillow block supports. Or to use the 'dual-l-vee' / bishop wise carver bearings.
    What are everyone's opinions.
    Apples :cheers:
    Jul 2004
    601
    How are things going? I've looked at the dual vee specs, and I think they may be overkill for a plasma table. But if you used them, you would have a killer router!
    Aug 2004
    104
    Hi everyone.
    Apples,
    What you're still deciding is about the way you will make the support to put the sheet to be cut on the table?
    Feb 2004
    427
    Going to use angle iron to support the sheets of steel. Building has stopped now as i have to fininsh putting up the front fence, retaining wall, lay the turf etc. etc. , Give me a couple months for further progress.
    Apples
    Jul 2004
    601
    I know how that goes, I'm currently building a shed, so a converted mill and plasma table will have to wait.
    Feb 2004
    2337
    The other way to look at it, is finish the machine, and the money you make from using your machine can go into paying someone else to do those other jobs.
    My option leaves you with a working machine and a built fence etc, as opposed to a unfinished machine and a built fence in a similar amount of time.
    Jul 2004
    601
    I need something to put the mill amd plasma in! And the cost of the shed has broke the bank. BTW it's a 12 x 30 garden shed with a 8.5' x 10' bi-fold door.
    Feb 2004
    427
    The only reason that i am making this plasma table, or the main reason is to make money from it. I hope to cut out parts for fabrication shops.
    I am a bit skeptical at the moment. Just wondering if it is worth building?Especially if i can't make money from it.
    I just hope that i can make money from it, otherwise i am down $15,000.
    Maybe i should just buy a bobcat and a small truck and get into that? What are everones thoughts?
    Cheers Apples
Page 1 of 7 123
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  2. I need to Build a 8’ x 30’ cnc plasma table
    By asil in forum Waterjet General Topics
    Last Post: 08-10-2005, 03:05 PM
  3. Need help finalizing plan for CNC Plasma table
    By David Bord in forum Waterjet General Topics
    Last Post: 05-26-2005, 01:16 AM
  4. CNC Plasma table plans
    By krazycnc in forum Waterjet General Topics
    Last Post: 05-06-2005, 03:51 AM
  5. My plasma table design
    By m_c in forum Waterjet General Topics
    Last Post: 07-24-2004, 07:01 PM
