586,114 active members*
3,310 visitors online*
    Aug 2007
    40
    MONITOR PROBLEMS
    Ok. I got past the soft overtravel problem. Now another problem has arrived. It seems like one step forward and 2 back with this machine.
    This is a W&S WSU with a Fanuc 10TF control. The monitor just started going blank after it is turned on a few minutes. I can power off then back on and it will work a few more minutes then go black again. The jog buttons still function when its blank so I guess there is no alarm. Just a problem with the monitor or power supply? Can anyone point me in the right direction to find the cause of this problem?
    Keith
    Aug 2007
    47
    That symptom looks like a dry electrolitic capacitor.
    Check the electrolitic caps in range 10-100uF x 150-350V in monitor PCB.
    The ideal instrument to do this is a ESR meter, but surely you wil find only few ones, so replace them directly.
    Eduardo.
  1. BOSS 9 monitor
    By shovelitdeep in forum Bridgeport / Hardinge Mills
    Last Post: 05-28-2008, 12:01 PM
  2. monitor
    By rusticr6 in forum Haas Lathes
    Last Post: 10-25-2007, 01:06 AM
  3. monitor
    By CASTLEVILLE in forum Bridgeport / Hardinge Mills
    Last Post: 10-11-2007, 12:37 AM
  4. Mazak T1 Monitor
    By bean79au in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-21-2007, 06:32 AM
  5. Monitor/DNC Trouble
    By big_mak in forum Haas Mills
    Last Post: 06-15-2007, 12:16 AM
