586,069 active members*
3,629 visitors online*
    Dec 2007
    20
    What type of oil to use
    I need to get my lead screws and ways cleaned up and lubricated since this machine has been sitting for a long time. What type of oil do you use? Same stuff for the ways and oil cups? Lead screws?
    Greg
    Dec 2005
    183
    I use Mobile Vactra.
    Dec 2005
    3319
    To cut thru caked on oil/grease, a more agressive oil such as WD40 or perhaps Dexron would do well. A 'way oil" such as Vactra is a good general purpose way lubricant.
    For a more interesting discussion about 'way oils", check out the thread that took place on the Tormach site here on the ZOne wherein a discussion of 4th axis lubes took place. There is a lot of good information sharted in the thread about good and bad uses of "way oil" in places wehre it should and should not be used. A good and entertaining read.
  1. CRC Type
    By binzer in forum GibbsCAM
    Last Post: 07-06-2007, 05:48 PM
  2. what type of collets are these?
    By rhino in forum Mechanical Calculations/Engineering Design
    Last Post: 08-08-2006, 01:07 AM
  3. Bearing type?
    By CNCgr in forum Mechanical Calculations/Engineering Design
    Last Post: 02-23-2006, 10:35 PM
  4. what type of control
    By skippy in forum LinuxCNC (formerly EMC2)
    Last Post: 10-12-2005, 11:36 AM
  5. what type of CNC do I need?
    By Goldhunter_2 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-25-2005, 04:57 AM
