586,096 active members*
3,459 visitors online*
    Oct 2005
    1237
    Generic name/term needed
    I want to buy some wire loom devices like I've found in the panel of my CNC mill. These are channels with fingers pointing up. Wires are run into the channel inbetween the fingers and once all wiring is complete, covers snap across the top more or less sealing the mess inside the channels. What are these called? I have no luck in my searches using "wire loom."
    Oct 2005
    1238
    Try this site for some similar to your description.
    A search for "cable management" might give some results as well.
    24221
    I think you are describing Panduct, made by Panduit, also other manuf offer similar.
    Wiring trough is another description.
    http://www.panduit.com/products/PDFCatalogs/068548.pdf
    Al.
    Albert E.
  1. Replies: 33
    Last Post: 02-24-2010, 10:39 PM
  2. Minor changes to Generic Fanuc Posts....
    By gearsoup in forum Post Processors for MC
    Last Post: 06-01-2007, 04:32 PM
  3. 1/4 - 20 generic vs acme?
    By 9xnet in forum DIY CNC Router Table Machines
    Last Post: 05-06-2007, 05:55 PM
  4. Need someone to edit generic MPFAN 9
    By CApostman in forum Post Processors for MC
    Last Post: 04-14-2007, 04:02 PM
  5. Generic(cheap) Encoder Source
    By mikkojay in forum Servo Motors / Drives
    Last Post: 04-01-2006, 10:27 PM
