586,080 active members*
3,485 visitors online*
Thread: Meldas 310
    Dec 2007
    41
    Meldas 310
    I have seiyo re 3016 machine and looks like memory batteries run out and I lost all perimeters. I will attach pictures and specs.If anybody have same or similar machine please let me know . I did contact Ameritech but they don't have any records because previous owners didn't keep records in order.
    HELP PLEASE!
    Darkospecs.txt
    Apr 2007
    29
    contact MEAU, if the machine tool maker cannot help you then you must explain this to MEAU, they have a library and they should be able to help you out.
    Jan 2008
    47
    if you look on the back of the machine you will see a metal plate with the machine builders name on it, what is that name?
    Dec 2007
    41
    PERIMETERS FOR SEIYO 3016
    P0N0L33751040L0L0L0L0L0L0L0L150L0L0L0L396312L1120L 0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L 0L0L0L0L0L0L0L0L0L0L0L0L0L1476395097L23040L0L0L0L0 L0L0L0L0L0L0L0L0L0L0L0L0L0L0
    P1N0L675287174L1207960901L1048832L67108864L0L0L336 85504L50L1090519040L0L0L0L0L0L0L257L8716308L262152 0L14417940L134217728L0L0L0L1140850688L393216050L19 660810L655423L3932160L65537L65537L65537L65537L6000 L6000L6000L6000L6000L6000L6000L6000L1000L1000L1000 L1000L1310740L1310740L100L6553600L0L0L0L0L0L0L0L0L 0L0L9999L0L0L0L0L0L0L0L0L0L0L0L256L16843009L335544 32L0L33554432L0L0L0L0L0L13107400L13107400L0L0L0L0L 0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L 0L0L0L0L0L0L0L0L0L268435464L2147483648L0L0L0L0L0L0 L1381184000L33751040L50331648L16777985L0L0L0L13107 200L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0
    P2A1N0L8000L2000L6000L0L0L290557340L193001280L4294 967096L4294967096L88152L2097169L9830550L9830550L98 30550L65736L20L0L0L65537L6553600L9830400L655360682 L134219776L33554944L80673586L0L5L1315400L39321750L 203161700L285281308L0L0L0L4887L695720672L807424093 L2216980124L696960544L33559963L512L3761631848L3840 1L1631209027L236075779L142778L302268960L576L211366 50L3226000L9678000L0L0L1107630374L201398528L107374 1823L3221225472L0L0L1892743986L50364544L33796112L1 112031296L33536L0L0L0L3459766101L67125248L17177601 L0L512L0L685444512L32768L1226087688L9437184L220204 6689L524544L41536
    P2A2N0L8000L2000L6000L0L0L547214L2152079904L429496 7096L4294967096L88409L134217745L9830550L9830550L98 30550L65736L20L0L0L65537L6553600L9830400L655360682 L134219776L33554944L80673586L0L5L1315400L39321750L 203161700L285281308L0L0L0L32768L1572289793L1677729 28L12616960L610339072L1024L0L2164344321L8454785L37 6225296L8422401L2291624858L17039632L36352L21136650 L3226000L9678000L0L0L2989521553L1233129472L1073741 823L3221225472L0L0L861420163L767561986L63109290L21 47511330L40452L0L0L0L38332962L612418560L2225114632 L11018240L6664L0L236941867L18688L2256863195L684802 144L34706294L9297L13334
    P2A3N0L8000L2000L6000L0L274000L33738913L147064832L 4294967096L4294967096L88666L2097169L9830550L983055 0L9830550L524488L20L465305600L60L65537L6553600L983 0400L655360682L134219776L33554944L80673586L0L5L131 5400L39321750L203161700L285281308L0L0L0L604046336L 3304149819L436323139L141840195L126877792L49153L0L4 15747010L1066496L1756805139L9065520L914737938L1685 1616L4096L21136650L3226000L9678000L0L107874L109802 0690L2281701680L1073741823L3221225472L0L0L10790265 25L134236434L563134L38835200L80L0L0L0L2248461600L8 84260880L71447200L276925520L107530L0L1427677206L13 4250496L2366081898L68200598L92859012L336097664L214 7524880
    P3A1N1L0L0L0L0
    P3A2N1L65537L0L0L0
    P3A3N1L131074L0L0L0
    P4N1L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0 L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0 L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0 L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0 L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0 L0L0L0L0L0
    P5N48L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L 0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L 0
    P6N103L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0L0 L0L0L0L0L0L0L0L0L0L0L10L327690L655360L0L20L327685L 327683L327683L327683L655365L327683L327710L65536000 L32768005L1L0L0L0L0L0
    P7N23L0L0L0L100L3932220L1582863L0L0L10000L65536000 0L0L0
    P8N96L0L0L0L0L0L0L0L0L0L0L0L65795L0L0L0L0L0L0L0L0L 0L0L0L0
    Oct 2023
    9
    Re: Meldas 310
    This is for Meldas 300, right?
  1. Meldas-m60
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-17-2008, 02:44 PM
  2. help with meldas mo
    By ToolC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-09-2007, 04:55 PM
  3. Meldas 310
    By mmurning in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-20-2006, 04:37 PM
  4. Meldas 500
    By pete v in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-08-2006, 11:17 PM
  5. DNC for Meldas
    By hpowell in forum Uncategorised CAM Discussion
    Last Post: 04-06-2004, 07:18 PM
