I have a 3 axis vertical machining center with fanuc o-md controller. When the tool path is a small radius or a sharp corner at high feed (about 100 ipm) difference between programmed tool path and actual tool path is quite big. (about 1/32"). I know that a part of this error is caused by acceleration/deceleration parameter. But can i improve accurancy by changing servo tuning parameter. Actually, parameters are the same for all 3 axis. Loop gain 2500, proportionnal gain -816, integer gain 91. I have some notion in process regulation but i am a new with servo tunning.
