586,055 active members*
4,172 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OT Control/Colchester 2000L Lathe
Page 1 of 2 12
Results 1 to 20 of 21
    Dec 2007
    I have a Colchester 2000L Lathe machine, it has Fanuc OT Control, when i turn the power on, screen show 0602-06, PMC :2-14 and says Not Ready.
    At the alarm message it says (Not Ready), but no alarm message, how do I get out of this Not Ready Mode. If knows how to get Fanuc OT control manual, need help.
    Thanks.
    Nov 2006
    925
    That is the normal screen for an OT on boot up.You now need to press machine start button.This should start the hydraulics and the screen should change to position then you reference it.
    Feb 2007
    156
    Make sure the E-Stop is not depressed or latched in the off position. Sometimes you have to turn them to the right to unlock them. Sometimes you have to pull up on them to unlock them.
    Dave
    Schneider Machine
    A force of one
    May 2005
    109
    try switch screen to system, position ...
    check for oil, air etc...
    Check for emergency stop, Over travel & mpcb trip
    Dec 2004
    75
    Our Fanuc OT's have this screen when booting up too but it disappears after a few seconds... except on one machine.. for some reason the "hang up" is caused by the bar feeder. we hit the reset button on the barfeed and then it is fine. so if you have a barfed, maybe that is it- if not, maybe the previous owner did and the control is waiting for a ready signal that will never come?
    Nov 2007
    17
    kz1670
    I have found that I have to keep the power "on" button depressed until the hydraulics kick in.
    Jul 2009
    18
    Dear Okhan.
    This message is cased bay many reasons, but what you can check is the Fuses and the circuit breaker inside the Main Fanuc system Box at the back side of the machine.
    Mostly one of the circuit breakers is on off mode
    Jul 2009
    18
    Need help :- Fanuc OT Control/Colchester 2000L Lathe parameters requierd
    Greeting Okhan;
    do you have the parameters fot the colchester 2000L lathe, i have the machine also and i reseted the computer by mistake.
    I dont have a backup for the Fanuc OT Control/Colchester 2000L Lathe
    i need the parameters and the maintinance manual if its availlable to you please
    my Email [email protected]
    regards
    24221
    Quote Originally Posted by Hakam View Post
    regards
    PM sent
    Al.
    Albert E.
    Jul 2009
    18
    Okhanan;
    Is your problem is solved or not?
    Dec 2010
    PM sent
    Al.
    Dear Al_The_Man.
    Could you be so kind, and share with me the Fanuc OT Control/Colchester 2000L Lathe
    parameters set and the maintinance manual if it's availlable to you,please.
    e-mail: [email protected]
    Great thanks in advance for your help.
    Best regards
    MacMG
    Jul 2009
    18
    Dear All,
    i have a problem with the Colchester 200l CNC, the machine boots up with the error 600-06 and "not ready" is flickering on the left side of the screen, no specific alarm number observed
    I have checked almost everything, EMG button, circuit, Fuses circuit breakers but with no success
    Anyone have the maintenance manual for Colchester 200l please share it with me
    Along with the cabinet contents diagram if you have it
    Email:[email protected]
    Jul 2009
    18
    Re: Fanuc OT Control/Colchester 2000L Lathe
    Dear all
    any one can help with the machine me error?
    Jul 2009
    18
    Dear All,
    hi any one have an idea about this error and what we can do to solve it
    May 2005
    109
    Can you upload the screen with error?
    Jul 2009
    18
    Dear Experts
    we need your help to identify the problem behind this error, I checked the servo cards and found seems to be no power
    the led on the cards are not lighting neither green nor red
    Aug 2015
    i have Fanuc OT Control/Colchester 2000L CNC Lathe Machine.
    can any one send me the parameter manual of above mentioned machine
    please share with me at [email protected]
    PM sent
    Al.
    Have same problem , lost the parameters and have no backup
    Could you send me a copy
    [email protected]
    24221
    Note:
    I do not have the actual parameters for any Fanuc machine, just the parameter manual on how to set.
    You require to contact either the OEM or someone with the same machine to obtain your particular settings.
    They are different for every machine depending on the builder or retro-fitter.
    Al..
    Albert E.
Page 1 of 2 12
  1. Colchester 2000L
    By bertcnc in forum Colchester Tornado lathes
    Last Post: 06-25-2020, 07:40 AM
  2. Colchester 2000L APC 310 and 320 Alarm
    By rjhzxc in forum Colchester Tornado lathes
    Last Post: 04-23-2014, 02:38 PM
  3. Colchester 2000L Fanuc OT
    By davee1987 in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2013, 10:26 PM
  4. FIRE!!Colchester 2000L Fanuc OT
    By davee1987 in forum Fanuc
    Last Post: 11-23-2012, 01:15 AM
  5. Need Parameters For Colchester 2000L CNC
    By Hakam in forum Colchester Tornado lathes
    Last Post: 10-27-2012, 02:46 PM
