586,106 active members*
3,303 visitors online*
    Oct 2005
    29
    No Output Signal
    Powered up system for first time. All 5 volt power from transformer and usb working fine. Hooked up drives as per instructions regarding setting com to 5 volts on a C1 board from CNC4PC. Tested drives with self test and they work. My home and limit signals work, as the leds go on and off when I activate these switches. I get no power (leds do not light ever) from my outputs. I am using Mach3 software and have verified my parallel port. I have the X,Y and Z enabled and on low active, but I get nothing when I try to tune the motors. When I power up the system I get a thump on each motor, like locking into place. Can anybody offer any help?
    Jan 2006
    51
    Try switching from low active to normal.
  1. code 86 dr signal off
    By CBNDude in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-24-2022, 07:06 AM
  2. end of bar signal
    By positiverake1 in forum Daewoo/Doosan
    Last Post: 08-25-2007, 01:34 AM
  3. Diag: Output Signal: Enable 1 help...
    By Flatline's Up! in forum Syil Products
    Last Post: 04-06-2007, 08:11 AM
  4. Getting analog signal from pc
    By roni21702 in forum Computers / Desktops / Networking
    Last Post: 06-15-2006, 07:34 PM
  5. Using the err signal
    By FrankdB in forum Servo Drives
    Last Post: 03-31-2005, 01:10 AM
