586,379 active members*
3,580 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > pully gears and belts for servos
    Jun 2004
    201
    I was told by Camtronics that I would probably need a 2-1 ratio timing belt drive for the clifton 420 oz servos we are thinking of putting on my X3.
    Where does everyone buy their pully gears and belts. Im looking for something that will possibly be in kit form.
    https://sdp-si.com
    I have some 53 tooth GT 5mm belts I can sell you. This Gates Powergrip is the bery best with no backlash and great torque rating. They retail for $8 each so how about $7 for both of mine?
    Proud owner of a Series II Bridgeport.
    Jul 2004
    148
    Pulleys
    You Can Check Out Mcmaster.com. Theyve Got Just About Any Thing.
    You Might Look At Timing Pulleys Or Maybe Some V-belt Pulleys. Im In The Same Boat You Are. Im Trying To Go As Cheap As I Can For My 3axis Mill. Not Sure Why A V-belt Pulley Set-up Wouln't Work. From What I Saw They Are Alot Cheaper Than The Timing Pulleys, And If You Can Get Enough Tension On Them I Don't See Why They Would Slip. Automobile V-belts Have Trouble Slippin
    Apr 2004
    100
    any of you know what size of pulleys works best on 63" travel?
  1. Questions about timing belts & gears
    By rc-cellar in forum Mechanical Calculations/Engineering Design
    Last Post: 04-28-2005, 05:09 AM
  2. Timing belts, gears, and ratios
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 12-20-2003, 02:09 AM
