First, I'd like to thank all the wonderful people on this forum for the pictures and ideas presented here. Makes it rather convenient to cherry pick the best of them and come up with something that fits my needs. I made this enclosure using 80/20 QuickFrame and locally available items. The motor is ducted to draw outside air for cooling, the 14 ga galv. floor is pitched towards the rear of the cabinet so coolant can waterfall into a collection gutter. The gutter (from Menards) is pitched to drain into a 10 gallon steel pail for recirculation. The Taig was mounted level on aluminum plates with flashing installed around the base. Silicone caulk seals all joints. The coolant is Oakflo DSS700. If I open the flow valve full blast, the coolant sheet flows into the gutter like a negative edge swim pool. Looks really cool.
