Hi all, I have Autocad 2000 and I'm using (trying) it for engraving in which I then save it as a dxf and then import it into LazyCam and then finally send it to Mach 3.
I've also used Solidworks 2005 and got the same results..when saving to dxf...
My problem is that when I set it up in lazycam, a font like Times Roman gets "split up" and the z axis has to go up and down around 10 times just to get around one letter because it treats each entity (curves and lines) separately.
Isn't there a way to "smooth" the font out and make the z axis start at one point and go all around the letter and when it gets back to the start point, THEN lift the z and go on to the next letter?
Thanks so much and Happy New Year!
Dave
