I wonder if this is possible, machine running is daewoo puma 2500st, the problem with tool load values that there is no way to "save" them, have to write them manually each time part changes.
Ie, if i put some subprogram call on start of each program which writes new values to tool loads.
10-20 tools, 9 possible axis on each tool + min max values.
(Ofcourse not using that many)
.. while at it, i could ask your opinion about the whole tool load system. It seems to be bit "flawed", kinda hard to get good working values which would stop the machine when needed etc.
... Dunno if i wrote this to right forum, correct me if im in the wrong place =)
