586,060 active members*
4,200 visitors online*
    Oct 2007
    20
    Tapping program on a Takumi Seiki
    Hello,
    Our 1997 takumi seiki V8a vertical cnc mill has the rigid tapping option. We used to do alot of tapping with it. I tried writing a tapping code for it recently, but it seems i have forgotten the proper format. It's still a G84 command but i believe there was an "E" in the code line for the thread pitch maybe? Any suggestions?
    thx
    2932
    What control?
    Are you getting an alarm? If so, which one? Please post the code you are having problems with.
    With rigid tapping, some machines need an M29 in the block just before the G84 block. Some controls allow you to use F for feedrate and E for pitch.
    Jul 2010
    Takumi Tap Post
    Takumi (mitsubishi Control)
    L100 (MANUAL TAP PROGRAM)
    G90
    G17
    X## Y## M01
    G92 Z0
    S### Z7.
    G84 Z-1.0 R.1 F(PITCH)
    G80
    M30
    INCH Feed Pitch
    1/4-20 200 0.05
    5/16-18 180 0.056
    3/8-16 160 0.063
    1/2-13 130 0.077
    5/8-11 110 0.091
    3/4-10 100 0.1
    1.0-8 80 0.125
    METRIC COURSE
    M6 x 1 254 0.039
    M8 x 1.25 203 0.049
    M10 x 1.5 169 0.059
    M12 x 1.75 145 0.069
    M14 x 2 127 0.079
    M16 x 2 127 0.079
    M20 x 2.5 101 0.099
    Feb 2006
    1792
    Rigid tapping with parameter setting
    This is one of the methods of using rigid tapping. There is a
    parameter which can be used to select between the standard
    mode and the rigid mode of the tapping cycles (provided the
    machine is capable of doing rigid tapping). On Fanuc 0i control,
    set parameter 5200#0 (meaning the rightmost bit of parameter
    number 5200) to 1, for the rigid mode. If the assigned value is 0,
    the tapping cycles would run in the standard mode. Though
    spindle start (M03/M04) need not be commanded in the rigid
    mode, the spindle speed (i.e., an S-word, say, S1000) must be
    commanded in some block, before the tapping block. Note that
    relatively high RPM can be used in the rigid mode.
    Rigid tapping with M29
    Specify M29 S1000 (if 1000 RPM is desired) immediately before
    commanding G74/G84. This will run the tapping cycles in the
    rigid mode. It is also allowed to command M29 and G74/G84 in
    the same block. And, the S-word need not necessarily be coupled
    with M29; it can be commanded in some previous block also,
    though it is a usual practice to keep them together. The rigid
    tapping mode ends with G80. For a subsequent rigid tapping,
    M29 must be specified again; otherwise standard tapping mode
    will be used.
    Rigid tapping with G74.2/G84.2
    On certain control versions, G74.2/G84.2 can be used for
    left-hand/right-hand rigid tapping. No parameter setting or M29
    is needed. However, S-word must be commanded in some previous
    block.
    Dec 2008
    5
    G84.1 and give a G code for F/rnd
  1. rigid tapping on Hitachi-Seiki HT-23J Lathe
    By jbird68 in forum G-Code Programing
    Last Post: 09-21-2007, 02:02 PM
  2. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
  3. Mori Seiki Sub program
    By adaptaflex in forum Fanuc
    Last Post: 06-20-2006, 10:03 AM
  4. Mori Seiki Sub program
    Last Post: 06-19-2006, 02:59 PM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
