586,055 active members*
4,176 visitors online*
    Nov 2007
    7
    Post Inspection reports
    Is there a website I can go to that will explane how to setup an inspection report? Are there any sample inspection reports available? Can anyone help with how to setup an inspection department? Thanks in advance for any help.
    Nov 2007
    Hi there,
    I suppose on what type of company you work for depends on your requirements.
    We are a sub contract CNC mill/turn shop working for Formula 1 motorsport, and British touring cars.
    The main reports required in an inspection dept that we run are:
    * 1st off critical dimension report
    * Final inspection report
    * Non conformance report
    * Concession report
    Setting up an Inspection department requires knowing what inspection equipment is needed, and putting in place the revalvent forms and folders.
    I use a lot of excel documents to monitor NCR's and concession etc etc.
    It totally depends of how critical quality is required within the company as to how in depth you need documents controlled.
    When you mention the inspection report i take you need the dimension report?
    cheers
    Nov 2007
    7
    Inspection report
    Thank you, I was looking for the dimentional report.
  1. Tool Inspection Machine
    By Smackre in forum Mechanical Calculations/Engineering Design
    Last Post: 09-25-2007, 10:06 PM
  2. SmartCam custom Job reports
    By Independent CNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-10-2006, 03:43 AM
  3. Used machine inspection
    By TR MFG in forum Fanuc
    Last Post: 03-02-2006, 03:48 PM
  4. ABOUT stop for tool inspection
    By marto74 in forum Haas Mills
    Last Post: 11-21-2004, 01:17 AM
  5. Do you like Wallcrawler weird news reports?
    By WallCrawler in forum Community Club House
    Last Post: 04-21-2004, 01:12 AM
