586,395 active members*
2,919 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Is there a new Postprocessor for MACH3 ver. 3.0
Results 1 to 13 of 13
    Jun 2004
    10
    Hi
    Is there a special postprocessor for the MACH3 Version 3.0 software.
    When I am producing Gcode form Partmaster CAD it seems OK but the small ARCs are substituted with the rest of the circle - i.e. a box with fillets in the corner will produce a Gcode of a box with 4 "big mickey mouse ears" one in each corner.
    This happens if I am using L1M_MACH3.PPR postprocessor
    If I am using L1M_MAXNC.PPR postprocessor instead everything seems to be OK - perfect handling of the ARCs and no "mickey mouse ears"
    Do anyone know the upgrade price for the Hobbylicence of Partmaster version 10 level 2 - I have got the Hobbylicence of Partmaster 9.x level 2 Includes CAD and CAM modules for Mill, lathe, EDM and Postprocessor and COMMS module
    Regards
    Geir Soland
    Norway
    Oct 2006
    975
    Hi Geir,
    Is this showing up when you load the file in Mach3? If so, you may be able to get past it by going to the Config tab in Mach, General Config. tab, and under the General Logic Configuration window the I J Mode has 2 choices with radio buttons(Absolute & Inc ) try selecting the other button for the I J Mode and see if the file loads with arcs instead of the full circles. I think this is what I ended up doing to correct this situation. Hope this helps.
    Regards,
    Regards,
    Wes
    May 2007
    428
    I'm not sure that pricing is allowed to be posted publicly due to forum rules. I have sent a PM to you! Also, did that work what Wes sent to you?
    Jun 2004
    10
    Thanks WES
    toggle this setting and changeing back to a 2005 edition of MACH3 postprocessor fixed the problem.
    regards
    from Norway
    Geir
    Quote Originally Posted by Dolphin USA View Post
    Unless they have been altered, the Mach3 posts I wrote and supplied to Dolphin should work. They are all ABS arcs.
    Working copies should also be available from Mach3 support group.
    Steve Blackmore
    Dec 2007
    341
    please tell me were to get the 2005 version of the mach three post processor i am having these problems two .what i was able to get in to mach was uninteligable and also looked like mouse ears .but now it it will just say this is not a rectangle or a circle and lock up your program. i tried changing the ij thing in mach no help. i finally got a hold of chad at mach support hes working with the progammer trying to figure it out. there is a heck of a problem when going from say a rectangle on one end and a radius on the outher end it looses its figgin mind .
    May 2007
    428
    You may be able to get past it by going to the Config tab in Mach, General Config. tab, and under the General Logic Configuration window the I J Mode has 2 choices with radio buttons(Absolute & Inc ) try selecting the other button for the I J Mode and see if the file loads with arcs instead of the full circles.
    Dolphin CAD/CAM Support
    Dec 2007
    341
    all ready tried it no change
    May 2007
    428
    The settings in the Startup Modals section for the IJ Mode may need to be changed to the other setting (Absolute or Incremental)
    or
    the opposite.
    This is very common for Mach users.
    259
    Geir,
    Try this post attached and also in Mach3 under config on the setup screen there is a box you can put commands that need to be remembered on startup.
    Type in G91.1 and close the program, then reopen it.
    This forces Mach to only read the arcs in incremental moves.
    http://homepage.ntlworld.com/stevens...M_MACH3INC.ppr
    Dec 2007
    341
    ill try that thank you the link you sent . it says it has been removed oh well but i will try the outher thing though
    259
    Link repaired.
    Sorry I renamed it INC at the end so it didn't over write the standard post and didn't update the link.
    John S.
    Dec 2007
    341
    thanks john ill give it anouther try
  1. Featurecam - Mach3 postprocessor (METRIC)
    By Chivo in forum FeatureCAM CAD/CAM
    Last Post: 05-22-2008, 02:10 AM
  2. BobCAD/CAM V21 and Mach3 Postprocessor
    By southernexplore in forum BobCad-Cam
    Last Post: 07-25-2006, 06:28 AM
  3. Corrected Mach3 Screens and Postprocessor Web Page
    By chris59 in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-20-2006, 10:12 PM
