I'm wanting to build a small dremel based pcb router, maybe 12"X12" overall with a 10"X10" work area, similar to one of the widget masters. I have 2 small slide rails for the z axis, 2.5" travel. I have 2- 3/8 shafts and roller bearings for the y axis, (seem thin) I also just aquired 2- 1/2 shafts and 4 derlin bushing bearings for the x axis. I also have 1/2 acme screws and derlin nuts to fit. From what I have read these parts seem sufficient for the job to me.... . Does anyone see any "Improvements" to that style of machine I should try? Or warnings about common goof ups that aren't easy to see until its to late? Also from what I have read 1/2 is most used but Will 3/8 Aluminum plates/bars (I have some) be thick enough for the build?
J
