586,096 active members*
3,378 visitors online*
    Jan 2008
    7
    dc spindle motor
    I aquired a old makino machining center.
    It has 3000c controls and a fuji dsr 83 spindle control, with a fuji ggg 31386 motor.
    I am retro fitting the controls to rutex. Does anyone know something about the spindle motor, and drive?
    I am mostly interested in motor wiring. I am convenced it is a series motor with 5 wires, 3 to the field.
    any ideas?
    24221
    Not familiar with that particular motor, but I would be very surprised if it was a series motor for a spindle, more than likely shunt wound.
    Most of the older DC spindles were 3 phase SCR drives.
    What HP is it?
    Al.
    Albert E.
    Jan 2008
    7
    motor
    The motor it 5.5/7.5kw 0r around 10hp. there is a 4 speed trans under it. i hooked the motor up to dc and it runs. I tried the kbcc225r last week, and it blew the fuse. the field now measure 22 ohms. the drive has connections for motor thyristors. This is a very large machine. anyone need 3000c stuff?
    Jan 2008
    7
    what is scr?
    24221
    SCR Silicon Controlled Rectifier, it generally pre-dates PWM (Pulse Width Modulated) drives.
    One advantage is you do not need a large DC supply like you do with PWM.
    Using a a phase shift control method, it uses the controlled rectifiers in a full wave bridge to vary the AC input energy to the DC motor.
    Al.
    Albert E.
  1. Spindle Motor Help
    By Ringleboy26 in forum CNC Machine Related Electronics
    Last Post: 03-24-2022, 08:18 PM
  2. Spindle Motor
    By Bobbyr70 in forum Phase Converters
    Last Post: 10-09-2007, 03:43 PM
  3. Servo motor used as spindle motor?
    By fatal-exception in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2007, 08:55 AM
  4. more rpms for spindle motor and spindle
    By bob1112 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-10-2007, 08:01 PM
  5. AC or DC as spindle motor?
    By svenakela in forum CNC Machine Related Electronics
    Last Post: 10-06-2005, 10:02 AM
