586,058 active members*
4,386 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Quick Little question
    Sep 2005
    84
    Can I save 2 versions of MasterCam v9 on the same system with one seat? I would like to keep the Metric and Imperial versions seperate. So IF I want to use the "Metric MasterCam" I would open that one, or if I wanted the Imperial, I would open that one. PLUS I could keep the drawings in each to help lower what I would need to look at. Thanks, John
    Clawsie
    Yes you can bring the part up, go to screen configure switch the config to metric save the config setting. it will ask if you would like to scale the part pick yes . do a file sav as metric.mc9. still in mastercam go back to screen config pick the config. file for imperial and save the config file. again it will ask to scale. save part as imperial.mc9.
    Steve
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Mar 2006
    1013
    As Steve said, you dont need to have 2 versions of Mastercam on your system. Just convert the "units" and save them as separate files. Less Hard Drive space wasted. You can still have 2 sets of "default setting" for Each environment (inch, mm).
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Sep 2005
    84
    Cool, thanks. I thought it was like that but just wanted that "second" thoughts on this matter. John:rainfro:
  1. New here, quick question 2T on TC-2
    By RonRoy2004 in forum G-Code Programing
    Last Post: 11-07-2005, 04:16 AM
  2. Quick Tig Question
    By Edster in forum Welding Brazing Soldering Sealing
    Last Post: 08-16-2005, 02:19 AM
  3. really quick question:
    By bigal in forum CNC Machine Related Electronics
    Last Post: 06-22-2005, 01:39 AM
  4. A quick question?
    By Bartman in forum Solidworks
    Last Post: 05-31-2005, 03:24 AM
  5. Quick V18 Question
    By Edster in forum BobCad-Cam
    Last Post: 12-13-2004, 04:53 PM
