586,094 active members*
4,110 visitors online*
    Dec 2006
    39
    Hall sensor connection
    Hi all,
    I have a question on hall sensor connection.
    I have an electric actuator with the following connection
    The hall sensor is supposed to connect to a PLC NPN input. The RED and BLACK goes to 24VDC and 0V DC respectively, YELLOW goes to my PLC input (which the PLC input common is pull high to 24VDC).
    However, The PLC can't "read" the signal from YELLOW. Sadly I do not have an osciloscope.
    While the actuator is moving, I measured across the YELLOW and BLACK and I get voltage like 12V, 17VDC....
    Did I miss out anything?
    Thanks all.
    24221
    You have a source device so your PLC should be sink input.
    Did you tie the GND to your PLC common?
    with the load resistors in place, you should get a high to low reading on the sensors without any connection to the PLC.
    Monitor with a voltmeter between common and Yellow, by turning the motor etc as slow as possible, before connecting to PLC.
    If you turn slow enough you should be able to read a 24v to 0 transition, too fast and it will be anywhere in between.
    Al.
    Albert E.
  1. Hall Effect Chopper
    By legomanww in forum CNC Machine Related Electronics
    Last Post: 12-20-2007, 09:11 AM
  2. Hall Effect Limit & Zero
    By Trebleplink in forum CNC Machine Related Electronics
    Last Post: 10-20-2007, 12:08 AM
  3. where can I buy encoders w/Hall for brushless motors for reasonalbe?
    By springlakecnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-17-2007, 10:05 PM
  4. Hall encoders
    By danSN in forum Servo Motors / Drives
    Last Post: 11-28-2006, 04:24 PM
  5. C-D track to Hall conversion
    By interflexo in forum Servo Motors / Drives
    Last Post: 07-30-2006, 01:07 PM
