587,011 active members*
3,786 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Swiss Macros and Tips, and advice.
Results 1 to 12 of 12
    Jan 2008
    21
    Smile Swiss Macros and Tips, and advice.
    I just wanted to create a thread where swiss users can list tips, and macro's they find helpfull, personally I am using a citizen A20, but to anyone who uses something different please list, im open to all sugg. just looking for new idea's, anything from skimming run time, to breaking chips, to best tooling for metels, or anything usefull for that matter. Thanks guys.
    Jan 2008
    8
    Fire away! Any questions, maybe I can help.
    Jan 2008
    16
    training for old Citizen F-20?
    Does anyone know where one can get training or basic instructions for a citizen F-20. Could use someone for a couple of weeks to help with set-up and basics. Thanks
    304
    Citizen Macro
    Sub Program to check if "Start Position" was performed before starting cycle. Add M98P222 BEFORE and movement in program.
    O222(CHECK-START-POSITION)
    IF[#810NE#816]GOTO30
    IF[ABS[#5043]GT[#814/2]]GOTO30
    IF[#5043NE0]GOTO1
    IF[#5041NE#824]GOTO1
    GOTO7
    N1
    M6 (CLOSE MAIN COLLET)
    (CUTOFF)
    T0100
    S1=#817M3
    G0X#814+.1T1
    /M52
    G99G1X#824F#822
    G4U.5
    M5
    N7
    (START POSITION)
    IF[#5022EQ[#872-#818]]GOTO991
    M7
    G4U.2
    G0X#824W0T0
    G53Z#872-#818
    M6
    N991
    M99
    N30
    #3000=70(--CALL-CUTOFF)
    Jan 2008
    21
    currently I am operating a citizen a20, is there anyone else here using that machine or a16, L20, L32?
    304
    all of them
    I have A16, A20 C16, K16, L20, L25, M16, M20, M32 Citizen's right out side my office door.
    Jan 2008
    21
    thank you to everyone for reposting, its nice to get input. We have only been running the citizens here for almost a year, here we run anything from plastics, to stainless, brass to 303 and 316. Currently for turning, we are using kennametal tool holders and inserts, I have no complaints and cost is pretty decent. We do spend a great deal of time on some jobs changing inserts on the harder materials, this is given, but I just wanted your input on what you use and how they compare, our most common inserts (although they change with material) are the KC5010, and KC5025 and occasionally KC730., also when running steel we have the given problem of breaking the chips, any advice without loosing cycle time, we often have to clear are chips off the front and back drills, we have a high pressor coolant system, but MOST of the time, is more of a pain in the ass, and it helps with cycle time but not so much with chips wrapped on drills.
    Thank you for everyones help and support!
    Oct 2007
    88
    does anyone know where to find the #5040's? wanting to take advantage of g160 on a citizen m20/m32. thanx a gazillion!!!
    Oct 2007
    88
    or better yet, does anybody know where to find the # for the guide bushing torque???
    304
    G160
    Here are the # for the machine positions. These will give you the axis shown for the $ sign you are in when you ask.
    What are you trying to do that you want the torque for the guidebushing?
    #5021= Macro variable for "X" current axis "Machine" position
    #5022= Macro variable for "Z" current axis "Machine" position
    #5023= Macro variable for "Y" current axis "Machine" position
    #5024= Macro variable for "C" current axis "Machine" position
    #5041= Macro variable for "X" current axis "Relative" position
    #5042= Macro variable for "Z" current axis "Relative" position
    #5043= Macro variable for "Y" current axis "Relative" position
    #5044= Macro variable for "C" current axis "Relative" position
    Oct 2007
    88
    i really want to use all the servo amp differences to make a macro in order to have my machine check and then eventually offset itself.
    Jan 2008
    21
    Quote Originally Posted by SWISS20 View Post
    I know there is another thread on tooling, but I didnt see anyone using kennametal, so if anyone that has there say in it, that would be great, thanks
  1. Best swiss tooling??
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 01-30-2008, 05:18 PM
  2. Help with macros
    By afterburn25 in forum Haas Mills
    Last Post: 04-09-2007, 02:19 PM
  3. anybody compare HT finecut tips to TD 1Torch tips for dross?
    By Knut in forum Waterjet General Topics
    Last Post: 09-29-2006, 07:17 PM
  4. Drafts: Tips for vendors and tips for RFQ writers...
    By InspirationTool in forum Employment Opportunity
    Last Post: 12-21-2005, 03:44 AM
