587,030 active members*
3,736 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Syil X3 Mill Spindle Speed Calibration Procedure
    Apr 2007
    80
    Hi All Syil X3 Mill Users,
    At the link below you will find the procedure that I used to calibrate the spindle speed of my Syil converted X3 Mill. The procedure calibrates the speed requested by Mach3 to the actual speed of the machine.
    I was always annoyed that I could never attain the maximum 3400 rpm under Mach3 control. The low end wasn't too bad as delivered but the top end was miles out.
    I have now adjusted my machine following this procedure and I am now happy. Of course the calibration is for speed settings with no overrides.
    Hope this helps for those who like myself wondered how to do this for 12 months.
    I was lucky that my machine front panel speed display was quite accurate when checked with my laser optical tacho so I did not need to adjust this. If any one knows how to calibrate the front panel rpm readout, please let me know and I will amend the procedure below so others can benefit.
    Kind Regards
    Chrisjh
    http://www.cjh.com.au/Syil_X3_Mill_S...alibration.pdf
    Mar 2005
    181
    Excellent resource. Thanks!
  1. 8x 36 knee mill spindle speed question
    By krumly in forum Knee Vertical Mills
    Last Post: 11-07-2007, 10:22 PM
  2. Sherline mill with spindle speed control
    By rozon in forum Benchtop Machines
    Last Post: 07-15-2007, 05:02 AM
  3. Taig Mill - need speed control for spindle
    By t2436jf in forum Taig Mills / Lathes
    Last Post: 01-24-2006, 10:37 PM
  4. What max spindle speed should a mill have ?
    By nashtm in forum Benchtop Machines
    Last Post: 08-05-2005, 08:26 PM
  5. High Speed Spindle for SIEG X2 Mill
    By whelen in forum Benchtop Machines
    Last Post: 07-27-2005, 09:58 PM
