586,119 active members*
3,699 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Looking for Panel Mount Connector. (6 pin)
    Sep 2004
    412
    Hello,
    I'm looking to get a rugged panel mount female connector with male cable side.
    I want to combine the motor feed and encoders into one wire. ((Is this a bad idea))
    2 conducters for the motor.
    4 conducters for the encoder.
    I've looked all through forum at a bunch of posts, but mostly I've just become confused or frustrated. The websites aren't the easiest to navigate.
    Anyway, any help would be great.
    Thanks.
    Sep 2004
    412
    I'm looking at using this wire. If it's required to use shielded with the encoder.
    The 16ga is much bigger than the 24 or so that the us digital encoder uses. I'll have to splice the 16/24 at the motor.
    End result is that I want to try and make the wiring as pretty as possible and reliable. I don't want wires running all over the place.
    If I should be looking at something else.
    Let me know... ((thanks))
    24221
    You could look at the AMP CPC connectors, they have a couple of larger pins in some units to allow for this.
    It is usually considered better to go separate connectors, but it is still done.
    Run the encoders in shielded pair cable with overall shield, and the motor conductors in either shielded or twisted pair cable.
    If you want a more rugged connector, the Cannon MS (Military Style), used on commercial machines is much more expensive.
    Al.
    Albert E.
  1. 10 pin connector help
    By Rees Guitars in forum Controller Cards
    Last Post: 01-20-2008, 07:29 AM
  2. Tool Mount For Jacobs Taper 3 mount
    By pzzamakr1980 in forum Tormach Personal CNC Mill
    Last Post: 03-29-2007, 08:31 PM
  3. Need help locating a connector
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 06-08-2006, 02:07 AM
  4. Need connector
    By cncadmin in forum CNC Machine Related Electronics
    Last Post: 03-17-2005, 07:26 PM
  5. 25 pin connector
    By polyhedron12 in forum CNC Machine Related Electronics
    Last Post: 02-23-2005, 11:40 PM
