586,112 active members*
3,035 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo power and encoder wire interference?
    Dec 2006
    51
    Can I run the servo power wires and encoder wiring (Cat5) in the same conduit or do I run the risk of interference? They are DC servos, G320 drives.
    24221
    Is done but not recomended if you have a choice.
    If You do, you should use individual shielded pairs and overall shield cable for the encoder and twist the armature conductors together.
    Al.
    Albert E.
    Dec 2006
    51
    Thanks Al,
    I would like to use the same conduit to clean up the wiring a bit, I'm going to try a shielded cat5 and a shielded power cable.
  1. router power cable interference
    By mxpro32 in forum Stepper Motors / Drives
    Last Post: 10-01-2007, 04:33 PM
  2. 3 wire servo?
    By eeyore in forum Servo Motors / Drives
    Last Post: 09-07-2007, 02:58 AM
  3. Which encoder wire?
    By CNC Pro in forum Servo Motors / Drives
    Last Post: 10-25-2006, 08:22 AM
  4. three wire encoder ... ??????
    By shahidmk in forum CNC Machine Related Electronics
    Last Post: 03-20-2005, 01:38 AM
  5. Encoder failure caused by Interference spike
    By Al_The_Man in forum CNC Machine Related Electronics
    Last Post: 08-20-2004, 05:26 AM
