586,094 active members*
4,033 visitors online*
Results 1 to 16 of 16
    Dec 2006
    45
    Unhappy Okuma-Howa manuals
    Anybody out there have, or know of, anywhere in the world to access manuals for an Okuma-Howa HL20 lathe. It's a 2000 with Fanuc 18T controller. Willing to beg, borrow, rent, or buy.
    Nov 2005
    174
    What are you needing out of the manuals? Sample codes, alarm list or programming format, I've got a 1999 ACT-20 with an 18T.
    Dec 2006
    45
    Hey rickyt, thanks for the reply!!!! Biggest problem at present is 'home zero' that wanders around(both axis, and turret position). This all started with a couple months of machine sitting idle,and the back-up batteries went dead; upon restart I had operator message EX 208 on screen, and alarm lite and beeper, and machine was alarmed out. Further digging showed ACP300 alarms for X,Z, and A(turret) axis. Replaced batteries and got rid of 300 alarms thru reset of 1815 parameters, and after MUCH fooling around, finally got rid of 208. However, turret doesn't seem to index like it used to, and in trial running (no work in chuck) an old practice program, the tool called for is not the one to index up(guess I may need to know how to do that,too). Anyway, when moving around axis's in manual mode, things seem fine, and 'home' mode goes back and lites come on; but when we run the practice program, the 'home' zero moves around on us(sometimes quite drastically). Repeated resetting of 'home' zero thru prameter 1815 has not got it to 'stay put'. Of course the Fanuc manuals take you just so far, and then refer you to your 'machine tool builder', NEAT!!! Any help would be GREATLY appreciated, Thanks howd.
    Mar 2009
    6
    we have recently purchased okuma 7 howa act-3 we want english machine manual if you have please confirm we have manuals in german language.
    Mar 2009
    6
    we have okuma & howa act-3 in manuals in german if you have in english please confirm.
    Apr 2009
    cncmaintenance delhi ncr
    Dear All
    RUN YOUR CNC MACHINE WITHOUT TROUBLE THIS IS FOR ONLY DELHI AND NCR CNC CUMMUNITY INDIAN CUSTOMER
    WE ARE BASED IN DELHI FOR YOUR SERVICE
    if your cnc machine is under breakdown and u want to start that
    then contact == [email protected]
    we work with all VMC ,DOUBLE COLUMN,HMC,turning cnc machine (imported one INDIA AND TAIWANI ) EQUIPED WITH BELOW MENTION CNC SYSTEM
    FANUC ,MITSUBISHI,MAZAK,MELDAS,OKUMA OSP,SIEMENS,FAGOR
    THANKS
    Apr 2009
    DEAR ALL
    Quote Originally Posted by CNCMAINTENANCEA View Post
    Dear All
    we work with all VMC ,DOUBLE COLUMN,HMC,turning cnc machine (imported one only) EQUIPED WITH BELOW MENTION CNC SYSTEM
    THANKS
    Mar 2009
    6
    how to set offset for 1st and 2nd tools for okuma & howa act 3 cnc lathe.
    Mar 2009
    1982
    what kind of control has this ACT3? is it Okuma or Fanuc?
    Jun 2008
    please help me, I have one machine daewoo milling model ACE-V500
    the machine have alarm No 2103 MUST BE COMMAND MANUAL ATC 1 CYCLE
    i don't have any manual, if any body have manual maintennance book, please can send to me
    Vu Tri Nhat
    Dec 2008
    3109
    Vu,
    Is your machine an Okuma ?
    or a Daewoo ?
    if it's a Daewoo (wrong)
    I don't think you will find a Kia part at a Toyota shop!!
    Mar 2009
    6
    Quote Originally Posted by Algirdas View Post
    it is fanuc 10t control.
    Jan 2010
    96
    This is for "howd", if you are still reading this post. I have the procedures for setting these home positions including the reteach procedure for the turret. It may be as simple as the way you are setting the 1815 ref position. Basically, if you already have a 1 in there then you change it to a zero, turn off control, turn back on, go back to the 1815 parameter and change it back to a 1 but then you must power it back off and on again or it will not take the change and hense the change you think you have made did not take and so the machine still has a bad ref position. If you have done it this way then we can look elsewhere. Let me know an e-mail and i can get these to you after the holiday weekend. These procedures are written by hand to include each button pressed. More detailed in laymans terms than factory. They are in Adobe pdf. Good Luck
    Mar 2009
    6
    it is fanuc 10 t control.
    Feb 2011
    hi
    I have problem ops300m error W02 but am dont have catalog okuma osp 300M
    what this error if you know?
    May 2008
    107
    Re: Okuma-Howa manuals
    Hi all.
    Is any one know where and how to get the manual of Okuma Howa CNC machine, model FM-30V with Sony NU-99 control unit?
    Or how to get, edit and tranlate program from/ to PC via RS232 port?
    Thanks in advance.
    Nam.
  1. Manuals available Howa Strong 860 & 1000
    By cncguy1200 in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2019, 10:27 PM
  2. Okuma-Howa ACT 2SP-2
    By crackshotcraig in forum Okuma
    Last Post: 11-28-2018, 04:36 PM
  3. OKUMA LB15 Shop Manuals, Electrical Manuals
    By Jimmyjam6979 in forum Okuma
    Last Post: 11-13-2017, 04:30 AM
  4. OKUMA HOWA ACT 3
    By jonirving in forum Okuma
    Last Post: 04-18-2011, 11:35 PM
  5. Difference between a Okuma & Okuma Howa
    By 69owb in forum Okuma
    Last Post: 06-04-2008, 05:51 PM
