586,036 active members*
4,109 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > loud beep at every key press? turn off?
Results 1 to 14 of 14
    Mar 2006
    103
    Is there a setting to turn off the loud beep at each keypress? I was looking through the manual and the user settings but I didn't see anything about changing the volume of the beep.
    Just got my VF-2 and SL-30 delivered yesterday! What an exciting day! I'll see if I can post some pictures of these two beasts and the fork lift that wielded them.. hehe
    cheers
    May 2006
    183
    Quote Originally Posted by pmurdock View Post
    cheers
    On the bottom of the control pendant, there should be a black knob. Turn it and it will adjust the volume of the key beeps.
    Nov 2007
    1702
    To clarify what Cory said, the beeper is located on the bottom of the pendant. The face of the beeper rotates to cover or uncover the speaker (adjusting the volume).
    Mine is fully closed and I still find it obnoxiously loud. I'm eagerly awaiting somebody coming along and telling a painless way to reduce it even further (before I jab a dental pick through it ).
    Greg
    Jul 2005
    12177
    Take the back of the pendant, take the beeper out of the bottom, wrap it in some foam and leave it laying on the bottom of the enclosure.
    Mar 2006
    103
    that's a pain.. It should be as simple as a setting with a value of 1 to 25 or something like that..
    it does help covering the speaker though.. mine came fully open and it was ear piercing everytime I hit a key.
    cheers!
    Paul
    Jul 2005
    12177
    You want a real pain or nasty trick for your second shift people? Turn the baffle so it is full volume and then go into the Settings and turn on Beep at M30. As soon as a program ends with an M30 the beeper starts.
    Nov 2007
    1702
    Quote Originally Posted by Geof View Post
    That's not the only time it's annoying. The TL-1 does it at tool change. It's beeping like crazy but I like to clear chips before swapping the tool and resuming the cycle. BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP BEEP.(chair)
    Greg
    Jan 2008
    35
    just pop the back off the cover and disconnect the white plastic connector.
    thats easiest on vf8s anyway
    >>>>>>>>>> Made In England <<<<<<<<<<
    Jun 2004
    84
    Duck tape.
    Sep 2004
    264
    I turned a bit of delrin rod as a pop-on cover for the beeper knob/opening, that brought the sound down to a manageable level. --ch
    Aug 2019
    Re: loud beep at every key press? turn off?
    cheers
    I just rolled up ear plugs really thin and lodged them in there and closed the volume adjuster. Peace, and Quite.
    Mar 2010
    1852
    Quote Originally Posted by MCnC978 View Post
    Eleven year old thread!
    May 2016
    526
    Take the back of the control off and pull the plug out from the beeper it's the easiest way
    cheers
    Setting 356 will turn it off also depending on the version different number can turn it down or up
  1. WANT MAZAK TO BEEP AT M30
    By robprec in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-04-2012, 07:03 AM
  2. Beep Volume
    By musall37 in forum Haas Mills
    Last Post: 03-09-2010, 10:15 PM
  3. getting control to beep
    By chucker in forum Haas Mills
    Last Post: 12-11-2008, 06:29 PM
  4. Turn off the system beep in Mach3?
    By fatal-exception in forum Mach Mill
    Last Post: 09-19-2007, 08:20 PM
  5. beep too loud
    By 1ctoolfool in forum Haas Mills
    Last Post: 03-26-2007, 05:40 PM
